Can High bottle pressure cause no n20!!
Need some help guys.Went to the track first pass out with new susp part car ran 10.6 at 126. next two pass same 1.50 60ft,but et wat down 11.1 at 121. Got back to lane and seen that i left heater on and bottle was reading 1300 psi Could that cause nos solenoid to stick.
Depends on the system. I know some solenoids are designed not to function over a certain pressure for safety reasons. Found that out on the dyno a few weeks ago. Pressure was at 1250 and the purge wouldnt even work, bottle cooled, pressure lowered to 1100 and everything was fine after that.
There NOS solenoids. I could purge the system,but time was off and mph. When i run a 60 shot 1/8 mph is 103 and 1/4 is 128. I was down to 96 in the 1/8 and 122 in the 1/4. When i got home and checked every thing out everything seem to be working then bottle was at 900 psi.
Originally Posted by SSwanner
its probably just "poor quality" n2o at that high of a pressure. i think the molecules try to diffuse under pressure that high.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Originally Posted by thechef
sounds more like the bottle is low or empty
are you making several passes on the same bottle??????
we always changed the bottle every pass for consitency
Originally Posted by MrDude_1
are you joking or stupid?
its not really a "safety thing"... its because teh 'noid has to open against bottle pressure, and if the pressure is too high, its just not capable of opening it.
Thanks for all the help
