n20 with 10 bolt
Old Nov 10, 2006 | 04:40 PM
  #41
Jordan S.'s Avatar
I've had mine rebuilt with Motive 3.73 and a eaton posi/ls. Had it on M/T's and Nittos and abused it its hole life. I'm about to go to a slick and see what happens.
On a stock one your rolling the dice.
Old Nov 10, 2006 | 05:02 PM
  #42
red fury's Avatar
Originally Posted by EndlessSummer85
yep mostly street driven, go to the track once and a blue moon, I was thinking 3.73. currently running the stock size 245 60r 16 but will probably get something in the 275 range down the road
245/60 16 is a bit taller 27.57" than my 275/40 17 25.66"
3.90's for sure with your tire!! Put some 245/60 16 DR's and go to town!
=126mph @ 6000 in 4th..........more than enough for the street
4.10's would work nicely at the track 1/4mile for a bolt on only M6.......=120mph @ 6000 in 4th
Just My 2cents!!
Old Nov 10, 2006 | 05:23 PM
  #43
NiCks Ws6's Avatar
when i get my juice, it will only be 100 shot, till i upgrade the trans and rear.
Old Nov 10, 2006 | 05:55 PM
  #44
EndlessSummer85's Avatar
I was thinking of useing tsp's rear end gear package, they have 3.23 3.42 3.73 and 4.11. I was just worried about running out of gear in 4th at the track with the 4.11, so going with 3.73 (motives) am I wrong??? or on the right track here?? Not totally sure never ran spray in a car before.
Old Nov 10, 2006 | 06:22 PM
  #45
red fury's Avatar
with a 245/60 16" tire and 4.10's you will be good to 124mph @ 6200rpm in 4th
you need to do find someone running a M6 bolt-on only with nitrous and the same tire size...........not easy to do but this is the place! Try the Drag Race results forum
Old Nov 10, 2006 | 06:51 PM
  #46
And I will thanks for the info!
Old Nov 10, 2006 | 08:30 PM
  #47
01_ram-air's Avatar
Originally Posted by JCurtin
Point being what? People say hooking up on nittos is impossible, its not. 1.7 60s with a lowered 6speed car on a stock 10bolt is fine and dandy in my book.
You have 440 hp and 560+ tq and you're barely breaking into the 1.7s. If you're happy with that, more power to you. With less than 300rwhp I'm cutting 1.6 60' times.
Old Nov 10, 2006 | 08:31 PM
  #48
01_ram-air's Avatar
I just noticed, you have a 4000 stall, you shoul be cutting under 1.5s. I dont know you can compare you cutting 1.5s to me cutting 1.7s on nittos, like I should be disappointed or something
I have a stock motor with 150 shot. And I have gone 1.49 a couple times. Ask around to see how many people are hitting 1.4 60' times with 0 suspension mods. You won't find very many that's for sure.
Old Nov 10, 2006 | 08:53 PM
  #49
gillbot's Avatar
I plan on running a 125 shot in the near future, and I have a quick question,
What rear end gear would be best for this??? I will have the stock 10bolt, and don't plan on spraying 1st gear... don't have the money for a 12 bolt
With an M6, don't waste your $ changing gears, just save for WHEN it breaks.
Old Nov 10, 2006 | 09:02 PM
  #50
john563's Avatar
xx2 thats money towards 12 bolt
Old Nov 11, 2006 | 09:40 AM
  #51
Yea I was actually thinking that too, I guess someday I'll have enough moneys for a 12 bolt.
Old Nov 12, 2006 | 07:24 PM
  #52
john563's Avatar
would using a progressive controller with time delay help preserve the 10 bolt?What I mean is that if its the launch is what kills the 10 bolt would delaying the n20 to come on help preserve it and that with a shot thats progressivly controled?
Old Nov 13, 2006 | 06:58 AM
  #53
gillbot's Avatar
it can but the 10 bolt itself is rather weak so there it no saying WHEN it will break. Many people break them at stock power levels but other's have taken them pretty far. I think it's mostly luck.
Old Nov 13, 2006 | 06:58 PM
  #54
raymond mckinney's Avatar
I'm running a TNT 150 shot and still have my factory 10bolt, I spray every chance i get from a stop with my 27' Mickeys, if it breaks it breaks it'll be fun!
Old Nov 13, 2006 | 09:07 PM
  #55
john563's Avatar
raymond
how long have you had the 150 shot and do you spray it atleast once aday?
Old Nov 14, 2006 | 04:29 PM
  #56
gillbot's Avatar
Originally Posted by john563
raymond
Stop asking questions and hit it with a 200 shot john!
Old Nov 14, 2006 | 07:49 PM
  #57
2001z's Avatar
9in with 4.11 gears from driveline solutions !!
Old Nov 14, 2006 | 08:03 PM
  #58
john563's Avatar
james
you first then ill follow
Old Nov 15, 2006 | 09:32 AM
  #59
amsterdamn's Avatar
I have nittos. Nothing wrong with them.
That's crazy to me. I bought used Draglites with Nittos and they spin easier than my cheap street tires. I kept them on for the track anyway, hoping there would be a difference, and of course there was not. Best 60' with Nittos = 2.26, then with MT DRs = 1.74 (I'm not spraying, yet). That's a huge difference.
Old Nov 15, 2006 | 10:00 AM
  #60
redline2k's Avatar
nittos are not as good as mt dr's but they are better than a street tire. I have cut 1.8 60's on nittos when my car was a six speed.
