How long will 75 hp shot last?
Originally Posted by David Gordon
If I put a 75 shot on my car how long will the bottle last?
Chad
At least 5 runs getting a full hit spraying out of the hole. You could go longer but you won't get a full hit because the pressure drops as the bottle is emptied. If you're only using it in blips to stay ahead to make money then a 10lb bottle on a 75hp shot will last quite awhile. Generally, you want to always have as close to a full bottle as possible though. I always refilled mine after every trip to the spot or track. That's when multiple bottles come in handy.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Originally Posted by Todd157k
It's like sex with the new wife... FAST and FURIOUS through the first bottle, then it tapers off, and you hit it A LOT LESS FREQUENTLY.. so after that, it should last quite a while. ![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Using the estimations you guys are talkin about I am gonna have to get a much bigger bottle and a filling station at home so I dont live at the filling station.
I prob shouldent even ask cause I prob wont wanna know but how long will a 200-300 shot last using a 10lb bottle.
Given: 10 seconds = 1 lb of nitrous at a 100 shot.
We'll assume you always spray for 10 seconds with a single stage.
If 100 shot = 1 lb, then a 10 lb bottle / 1 lb per run = 10 runs
You want a 200 shot? 200 shot / 100 shot = 2
(2) (100 shot) = (1 lb used) (2) by the Distributive property.
200 shot = 2 lb used
If 200 shot = 2 lb used, then a 10 lb bottle / 2 lb per run = 5 ten second runs
Using a 300 shot? 300 shot / 100 shot = 3
(3) (100 shot) = (1 lb used) (3)
300 shot = 3 lb used
10 lb bottle / 3 lb used = 3.333333333333333333333333333333333333 ten second runs
...if you're lucky to get every last drop out of the bottle -> https://ls1tech.com/forums/showthrea...28#post4304128
Originally Posted by Somebody09
You're right you probably shouldn't, but not for the reason you mentioned...
That push system is neat looking and seems to work I guess, I haven't seen it in person or talked to anyone using it. But it would appear to be overkill on a single stage medium sized setup just to save trips to a filling station or running spare bottles.
