We are proud to announce Outlaw Stand Alone Fuel Systems
Gun Jumpers! Next time wait til you get the pics.... or do something sneaky, like have a "customer" leak the info onto the board, so you dont get the "this thread is gay without pics"
Tenured Member
Originally Posted by craz1469
im dumb............whats it used for
Tenured Member
Ok here is a rough cut of it. It will be a little different for the pump mounting due to the fact of the Sway Bar and A/C being there.
Its a
1 Gallon Cell
Holly Blue Pump with Regulator
-8 Line from the Tank to the Pump
-6 out from the pump to the regulator to the solenoid
-6 over flow
The kit pictured here is all done in anodized black fittings. This is the more expensive route and is a upgrade. It will come with Red/Blue Common fittings.
Other options will be
Black Line
Powder coated Regulator and Fuel Pump Brackets and Fuel cell.
This kit obviously goes in place of your battery which will have to be relocated to the back. For most that will order this they are probably drag racing and already have the battery in back. You also must remove your coolant overflow tank, we supply you with a aftermarket mini moroso. Not shown in the pic is the custom bracket that will allow you to mount the cell to the core support. All lines will come complete and upon request we can flowjet the regulator for you.
Stay tuned for more pics.
Its a
1 Gallon Cell
-6 over flow
Black Line
will the track let you run the regulator on the frame rail?
I thought i remembered Madman saying it had to be on the motor for some reason *lost*
Looks VERY good though.... very tempting to ditch my home brew setup for this
