Popping On Nitrous
Old Jan 8, 2007 | 07:38 PM
n20addict's Avatar
Default Popping On Nitrous
ok as soon as i hit the nitrous shot(wich is a DP progressively controlled 380 shot that starts at 50%) it starts popping for maybe like a half of a second. the a/f drops to 9.7 or so and then goes up to 10.5 and takes off like a raped ape but it only happens when i first hit it.
anybody have any thoughts?
thanks
Old Jan 8, 2007 | 08:24 PM
Nitro Dave's Nitrous Outlet's Avatar
You are going to rich on the hit. If the poping is through the exhaust that us unburned fuel.
Dave
Old Jan 8, 2007 | 08:37 PM
n20addict's Avatar
dave
what jet sizes would you recomend? i am currently running NOS .032 and .018 jets
Old Jan 8, 2007 | 08:42 PM
Ok so it starts off at the 9.7 and then leans to the 10.5 correct.. Howdoes the airfuel curve look NA. Is it flat?
You need to get the airfuel to about 11.5 to 11.8 on the juice..
I would start with making sure the nitrous solenoids are firing and that there is not flow restriction. If all is good start by going to a 16 fuel jet.
If you have a dedicated after you make the jet change and get close on the airfuel you can adjust the rest with fuel pressure.
I am at home and do not have my jetting cards with me to double check jetting for you.
Thanks
Dave
Old Jan 8, 2007 | 09:01 PM
n20addict's Avatar
well dave i am trying to learn how to tune with hptuners and the tune that is on the car right now was tuned by a different tuner and on motor it is flat at 10.5 witch i know is way too fat but i dont know anything about tuning so i havent tried ajusting ve tables yet do you think if i get my n/a a/f up to about 11.5 - 11.8 that it would bring my nitrous a/f up to that also? also i appreciate the help.
thanks
jason
Old Jan 8, 2007 | 09:08 PM
Yes, If you cahnge your NA tune it is going to change your Nitrous Tune. I suggest getting your NA tune right before continueing trying to tune the nitrous. Other wise you will be fighting a loosing battle. Give this guy a call. He is very helpful. Tell him I told you to call. He tunes at our shop and this is his cell number. 254-644-2656. His name is Moe Bailey.
Dave
Old Jan 8, 2007 | 09:10 PM
n20addict's Avatar
ok thank you very much, dave
jason
Old Jan 8, 2007 | 09:16 PM
No problem. Feel free to hit me up for any further tech help to get you on the track spraying safely.
Dave
