NOS LS1 NOSzzle Direct port kit
Race your car!
that is a very good kit... ther's a few guys on here that have used that and have gone very fast with it. IMO, it's one of the better systems out there, but it's not really common for some reason.
PM noyzee on here, he ran that setup on his 346 and ran a best of 9.4 with it if I remember correctly.
I do also know, that it will not work with a fast intake for some reason, something about the nozzles not fitting under the injector right or something.
8 second mod
i liked my kit alot. just be sure to line up your injectors so they spray right threw the hole, be sure that the mist/spray from the injector isnt hitting the sides of the cup. if you do that, and richen the rear 2 cylenders atleast 2 sizes. (say your running 26 in the fuel side on all of them, bump #7 and 8 to 28's
other then that, i liked the kit alot. use it with stock rails, and its even better!!
good luck, hope it helps
i bought it off someone from the board a while back. can't really remember how much i think it was two years ago or something like that. reason i'm selling it is i'm building a 383 and i need money for machine work and other stuff like headers head studs, stuff like that. i plan on doing a plate setup with my single plane once i decide to juice.
LS1TECH Sponsor
Kyle
8 second mod
Originally Posted by Z284U2TRY
Does anyone do this with a regular direct port?
i always start off like thet, then read the plugs and adjust it from there.
i just find most of the cars i have done seem to go leaner towards the rear cylenders
Race your car!
Originally Posted by Kyle@NOS
With the injector 3/4" taller in the NOSzle it either won't clear the runner or it doesn't sit at the correct angle on the FAST manifold. I can't remember exactly but it's one of these.
Kyle
Kyle
Yeah, I don't knwo which it is, but it's one of the 2. it's too bad really, because if that setup would work I'd be putting one directly on my car. I'd go back to a ls6 intake, but I think the fast 90 is barely enough intake for my 402 as it is.
