Progressive controller for big noids
Old Feb 9, 2007 | 04:22 PM
scapaldo's Avatar
Default Progressive controller for big noids
Ive got the HSW bottom outlet N2O and fuel solenoids and Im looking for a simple progressive controller for them.
I dont want to downgrade the noids because Im going to be spraying a 300shot through them and dont want to max smaller noids out. Also my plumbing is finished and I really dont want to redo it.
I want to stick with a basic function (three **** style) controller because I already have a window switch, speed switch and timing retard built into my ecu. I also dont want to pay for an FJO.
Alternatively:
Is there any way that a Controller that is limited to ~30amps can control 2-20+ amp noids? Like using the output of the controller to trigger 2 different relays, 1 for each noid? I want to use the controller I have now but it just doesnt handle the load of both noids.
TIA,
Stefan
Old Feb 9, 2007 | 04:45 PM
DynotuneN2O's Avatar
LS1TECH Sponsor
Our controller handles 40 amps.
http://www.dynotunenitrous.com/store...?idproduct=216
Dean
Old Feb 9, 2007 | 05:26 PM
scapaldo's Avatar
Problem is, these noids draw a little over 20amps each. Even if it works once, would it fail to open them eventually?
My car already saw 15:1 AFRs on the dyno because of this, I'm hoping to avoid that again
Old Feb 9, 2007 | 05:32 PM
860 Performance's Avatar
You should recheck your amp draw. The N20 solenoids are typically over 20A but the fuel solenoids are usually under 10, (even big ones).
Old Feb 9, 2007 | 05:35 PM
scapaldo's Avatar
Ill definately check that out. When I found out that I had a problem, it was the fuel noid that wasn't opening. They were wired together but the wires directly to the fuel noid were about 12" longer.
The controller Im using is rated at 30A.
Old Feb 9, 2007 | 05:42 PM
You have a different problem than you think.
Just out of curiosity, did you do a full pull on the dyno? Did the A/F stay lean or was it only lean while the solenoids were pulsing?
Old Feb 9, 2007 | 05:49 PM
scapaldo's Avatar
It was a full pull, but I was just checking AFRs on 30%(~130hp) the whole time. It stayed very consistent throughout the pull also.
Triggering them with the car off and the N2O solenoid pulses but the fuel just clicks once very quietly. Disconnecting either solenoid results in a very strong pulse from the other one.
I wired a single relay to be triggered by the output of the controller instead of driving them directly and it didnt help at all. Im planning on trying to trigger 2 relays, one for each noid, and see if that works.
Old Feb 9, 2007 | 05:58 PM
Ok heres your issue:
1st do not run a relay off the output of the progressive controller. They can't take that abuse. they are not designed to be pulsed that fast, and burn up real quick.
2nd. Heres why your lean.
N20 is compressable and fuel isn't. When you run a big N20 solenoid it fills the line between it and the nozzle. The line acts like a resivoir, and the solenoid just keeps topping it off, while the actual flow rate through the jet stays nearly constant and at nearly 100% depending on the relationship between the Noid oriface and the jet oriface, as well as the line length. Since the fuel dosent compress it actually will run well at differnt %'s.
What to do? If your really set on running a progressive controller, try a small nitrous solenoid, with the same jetting. That makes a big difference.
What size jets are you using?
Vinny
Old Feb 9, 2007 | 06:06 PM
scapaldo's Avatar
Ill have to check on my jet sizes because I dont have them in front of me. The N2O not compressing does make sense but the fuel noid definately isnt pulsing. I went from ~11.5:1 on boost only to 14:1 on then it rose up to 15:1 as nitrous came on. (just rechecked the logs and dyno sheet)
Ill have to get back to you on jet sizes but its calculated at 4 nozzles 43psi fuel 950psi nitrous jetted to 300hp total. I would really like to progress it only for about a half second though, just to let the tires hook.
I also have the N20 and fuel noids staggered to try to prevent a lean spike.
Old Feb 9, 2007 | 06:13 PM
scapaldo's Avatar
Heres what I mean by staggered. The fuel noid is now connected to the red splitter on the firewall. The N2O noid is in the wiper tray feeding the distribution block via the black line from the bulkhead. The bulkhead on the far left on the firewall is the 2nd stage, ingore that though.
Old Feb 9, 2007 | 06:40 PM
o.k. that clears some things up. If your jetted to 300hp then you have properly sized noids.
Do yourself a favor, hook the noids back up to the progressive controller. Disconnect the fuel solenoid from the distribution block and point it into a bucket. With your bottle off,turn your fuel pump on, and pulse both solenoids. See if fuel sprays out. This is a much better test than listening to the noids. See if it is infact spraying or not.
If it is spraying fuel. They try 2 things.
1.Eliminate the long line between the N20 solenoid and the distribution block. This is an easy way to help prevent a lean spike, but dosen't work with progresive controllers.
2.Monitor fuel pressure during a dyno pull. Eveyrthying may be set-up right, but you will now need some serious fuel supply.
Old Feb 9, 2007 | 08:07 PM
scapaldo's Avatar
Ill try that with a bucket. Even though I am about 99% sure that its not fully opening. Running just the fuel noids results in feeling/hearing the loud clicking, far different from when it has the N2O noid hooked up with it. Its definately worth checking though.
Fuel supply shouldnt be a problem, Im running an A1000 pump with only 400whp on boost and -10 line feeding 2 -6 lines, 1 for the fuel rail, 1 for the fuel noid. The extra 130hp shouldnt have caused the massive lean condition. I can log nitrous activation in relation to AFR and there isnt a slow rise, it takes a huge jump on activation.
Old Feb 9, 2007 | 08:17 PM
LS1SpeedAddict's Avatar
HYUNDAI
Old Feb 9, 2007 | 11:13 PM
scapaldo's Avatar
Yep, only the best for my car
Old Feb 10, 2007 | 07:58 AM
Thats cool, I just would never expect to see that on a Hyundai. Throw some more pics up.
Old Feb 10, 2007 | 08:38 AM
scapaldo's Avatar
I was messin around, its an Eclipse. Alot of hyundai parts are interchangeable so I have them around, hyundai block, crank and oil cap.
Old Feb 10, 2007 | 03:34 PM
Robert56's Avatar
Here's another controller, a little more $$, but you know the old saying... It can handle 4 of the big PRO noids at one time.
Nitrous Direct Controllers
Robert
Old Feb 10, 2007 | 04:07 PM
scapaldo's Avatar
Sounds like that may be a good option. It wouldn't have any problem handling 2 large solenoids?
Old Feb 10, 2007 | 04:09 PM
scapaldo's Avatar
Jet sizes are .023 / .041 x 4 BTW
Old Feb 10, 2007 | 04:23 PM
Robert56's Avatar
Nope, it will handle 4 large noids.
Robert
