NX intake, NXL DP system, 85mm TB
just got it in today. normally, this kit would have nozzles that go under the fuel injector. i got their LS intake that has the ports drilled into the intake for the nitrous and fuel.
the intake
here's a close up of where the nitrous lines will go to just like if you had a nozzle.
here's what it looks like inside the injector hole where the nitrous and fuel will come out
the underside of the intake has a 1/4" thick aluminum plate
inside the intake
the NXL direct port kit replaces the factory LS intake fuel rails. this way, it pulls fuel right off the rails
the fuel accumulator. this helps with the initial hit of the system.
the 85mm TB
the intake
inside the intake
the 85mm TB
Closed ex-Sponsor Account
That intake is discontinued. Had to many problems with the casters. So whom ever gets one there will only be a few out there at this time. Intakes are 850.00
535.00 on the throttle body. Again limited supplies.
Ricky
Ricky
Sweet, what a trick system this will be. Can I ask one question, and not meant to bust your *****. Why use the NXL rails, as they have the largest volume and are hardest to keep full on intitial hit? Though, they are about the trickest look when plumbed with the Kevlar lines, imo.
Robert
Robert
Robert
Robert
Originally Posted by NXRICKY
No they do not. The holes feeding the system are realitivly small. And shorter then if using a conventional rail system.
Robert
Originally Posted by Got Me SOM
looks good robert, wanna put it on my car and test it out?
this going on your ride i suppose?
yep going on the black car. along with some other things.
Originally Posted by mrr23
sure. so long as i can test your blower on the wife's car.
sweet! looking fwd to seeing how the new setup works out for ya. pretty soon i will be the slowest car in orlando.
(well for the time being )
ah, i'm pretty sure you'll keep up with me.....
well, maybe not with what i've got going on.
i so, want to put a blower in the wife's car. but, it's a serious chunk of change right off the bat.
