SCE ICS Titan Gaskets...
Old Feb 16, 2007 | 11:53 AM
Slow Z28's Avatar
Default SCE ICS Titan Gaskets...
needing headgaskets for the buildup. anyone using them and having good luck? what was the part number you were using? summit's website is a bit hard to read to make sure i'm getting the RIGHT ones.
to get my quench where i'd like it, i'd need to use there .043 compressed gaskets (.008 out the hole).
see alot of people using the MLS gaskets, but at a .054 compressed, that quench area is awefully big if we are supposed to be aiming to get it around .035ish.
already have the ARP studs for the setup
Old Feb 17, 2007 | 12:51 PM
pewter 01 SS's Avatar
Try Going To The Sce Titan Gasket Directly. Im Using Them They Are Really Strong. I Got My Part Number Directly From Sce Website That Is Really Easy To Read And Ordered Them From Summit And Got Them Direct From Sce. It Was Like A Two Day Turn Around. My Friend Was Runnig Them On His 408ci That Blew Dew To Detonation We Think The Piston Melted Before The Gasket Went Out. That Shows You How Strong These Gaskets Are
Old Feb 18, 2007 | 12:08 PM
NEVR2ND's Avatar
I am using it and got it from Jegs because they had in stock. SCE Part number is S11954LS.
Old Feb 18, 2007 | 01:53 PM
Slow Z28's Avatar
sweet, i thought i read somewhere that you are supposed to permatex some areas. did you do this and what areas where they talking about?
Old Feb 19, 2007 | 11:59 AM
NEVR2ND's Avatar
I sprayes the whole gasket with cooper gasket sealer for extra protection.
Old Feb 19, 2007 | 03:02 PM
Noyzee's Avatar
8 second mod
i have used 4 sets of these on ls cars and a couple on stangs. the ls cars all seeped exept the ones i used copper spray. i like the mls much better. i damn near kiled my motor do to #1 cyl leaking water into the hole. kicked back real good. broke the starter in half!!!!!!!
will never use them again
Old Feb 19, 2007 | 04:28 PM
NEVR2ND's Avatar
I was not able to use the GM MLS gaskets do to my heads having the notch in them. I hope I won't have any problems with this SCE gaskets taking in consideration they are $$$. The GM graphite gaskets worked OK with a 225 shot.
Old Feb 20, 2007 | 06:28 AM
Slow Z28's Avatar
Noyzee, how far outta the hole are your pistons?
with how big those gaskets compressed, it just puts me out of my safety zone, but it seems EVERYONE is using them. so is your engines quench just not taken into account, or is everyone's pistons sitting out the hole .015 or something
Old Feb 20, 2007 | 11:36 AM
Noyzee's Avatar
8 second mod
i donnt remember it was a while ago, but i know they seeped and leaked water and filled up the hole
Old May 18, 2007 | 11:49 AM
NEVR2ND's Avatar
Stay away from SCE headgaskets. I didn't even have a chance to start the car. I added coolant and bouth headgaskets leaked. What a waste of $225.
Old May 18, 2007 | 11:56 AM
Jimmy P's Avatar
If anyone needs a set for their 346, I have a set laying around. I would of used them in my build, but I ended up going with a 402. This is the first time I am hearing about them leaking.
Old May 18, 2007 | 12:05 PM
allthrotle's Avatar
Ive only heard of them leaking on boosted applications, where they pull coolant. The stock MLS gaskets blew on my buddies procharged motor and he was only running 10lbs.
Old May 18, 2007 | 12:19 PM
ATVracr's Avatar
Cometic MLS work great for us.
You can get those in .043
Old May 18, 2007 | 02:58 PM
Noyzee's Avatar
8 second mod
i hate to say i told you so
Old May 18, 2007 | 06:09 PM
NEVR2ND's Avatar
By the time you posted it was to late for me.
Old May 18, 2007 | 06:43 PM
Slow Z28's Avatar
saved me, but sucks on your end
i gotta get my thing started so i can see if my Felpro MLS stuff leaks. Heard alot of good things from a number of people with them.
