LS7 Clutch & Nitrous
Old Feb 25, 2007 | 02:01 PM
ShaneD_06GTO's Avatar
Default LS7 Clutch & Nitrous
I'm about to pull the trigger on an LS7 clutch kit, but was wondering how it was holding up for you 100+ shot guys. The stocker can barely handle 375/374 without getting soft on me. Did you need the cylinder slave and pilot baring too? All experiences would be appreciated.
Thanks,
Shane
Old Feb 25, 2007 | 04:05 PM
93camaro_zzz's Avatar
I got the LS7 clutch and am getting ready for spray. At least on an F-body, I purchased an 02 slave, since my car is a 2000. But you should always do the pilot bearing while your in there. Its literally $5, and a rent-a-tool. Havent sprayed yet, but was wondering the same as you if the clutch would be good. IMO it should be, since I have seen more than one sprayed LS7 vette.
Old Feb 25, 2007 | 06:45 PM
Robert56's Avatar
The ls7 clutch can't even handle the stock 450rwhp of the new c6 Z06. So the torque spike of your nitrous hit will likely make short work of the clutch. Cheap is not allways better.
Robert
Old Feb 25, 2007 | 07:25 PM
Phlip00WS6's Avatar
Its workin for me so far.. about 50 lbs threw it.
Old Feb 25, 2007 | 11:24 PM
Robert56's Avatar
You must be doing some soft launches. Max on a new Z06 is 3800rpm, then it just gives out. Check out the C6 Z06 section at corvetteforum if ya guys don't believe me, it's straight from the guys racing this car/clutch. It is by matter of fact the weak link.
Robert
Old Feb 26, 2007 | 01:03 AM
So then why can people spray stock clutches or LS6 clutches, but yet the LS7 just sucks? Maybe you cant spray first gear on a 5K launch, but otherwise I think it should be ok, or am I wrong?
Old Feb 26, 2007 | 05:53 AM
2001z's Avatar
I have heard these clutches get real soft when you start leaving hard with spray! I believe when you start getting the 400rwhp zone it starts getting to be a problem . so most of the people not having troubles either are not making that much poer or leave the line at 3 grand or so ! I would def look into getting something that is a little more sticky and can hold alot more power and the tq curve ! Just my .02$
Old Feb 26, 2007 | 08:21 PM
Robert56's Avatar
My stock ls6 clutch couldn't hold a 100 shot, and would stick to the floor on hard shifting n/a runs. first time I sprayed it it slipped like a bitch. Ls7 is slightly better, but when spraying the torque spike is so massive stock style clutches just don't have the clamping power.
Robert
Old Feb 26, 2007 | 09:03 PM
AdamSS's Avatar
How bout spraying on 3rd gear, and not on launches ? Would Ls7 clutch handle that ?
Old Feb 26, 2007 | 11:55 PM
Thanks to all who responded. It looks like the textralia clutch is right for me.
