info on refill stations
what all is needed?? i am looking at a zex refill kit or a nitrous outlet kit..with the pump and all..
how much does it cost to rent and refill the "big" bottle usually?
is there a scale or how do you know how much you have filled the bottle it doesnt look like the kit comes with a pressure gauge?
any help would be appreciated. thx aaron
It's not necessary to use a pump, I have absolutely no problems with just putting my bottles in the freezer and filling them once cold. Most of the shops around here fill them this way as well.
I need to get the mother bottle(s) contract w a gas company in May, and I will be up and running.
$85 for a 56lb mother tank.
equates to just over $1.50lb.
its a wise choice if u use alot of juice.
and it actually becomes quite the good little $ maker for the afterhours, laten ight street scene guys @ $5lb.
i've had them lined up down the street before...LOL
how many lbs can you get into your 15lb bottle by doing the straight transfer?
what size is your fill bottle and can you get all of the nitrous out of it? or do you need a heater, compressed air, or something else to force out the nitrous at some point?
I usualy overfill my bottles by at least one pound so getting a good fill has never been an issue for me. its very important to get the host bottle as cold as possible
nothing extra is needed. You do not want to heat the mother bottle it will cause more of the liquid to become a vapor.
there have been a lot of threads about this over the years i search would do wonders on this
