How Accurate are electric fuel pressure gauges? (Nitrous related)
Are these pretty accurate? I am running a 100 wet shot and when the nitrous kicks in, the gauge goes to 40psi for a split second, then went back to 60. I have a Walbro 255L in now and show 61psi at the rails.
Is it time for an inline fuel pump?
Thanks,
Jason
Thanks,
Jason
LS1TECH Sponsor
Thanks,
Jason
Thanks,
Jason
Dean
Originally Posted by DynotuneN2O
How accurate totally depends on the gauge,. If its a Dynotune fuel pressure gauge it is accurate to .1 PSI.
Dean
Dean
Well, unfortunately is not. It is an autometer fuel gauge. One of the older models no less.
I forgot to mention that when I hold the rpm's at 3500, then nail and the nitrous comes on...there is no problem. On the other hand, when I am in 3rd(lets say) and I let the rpm's rise, thats when I get detonation and fuel lose. That make sense...it's hard to explain...
Originally Posted by oange ss
the wiring would help, but probably wont cure it...i have a RaceTronix pump, 62 psi@idle...56 psi@ WOT/NA....53 psi@ WOT/ 100 wet shot...
I know I should not need a dual pump setup. At WOT/NA my pressure only to 58 psi, no lower.
You think my injectors have anything to do with this?
Like Orange SS already said, its a inherent problem with a return-less fuel systems.
A fuel pump might help a little, but when your nitrous clicks on it draws a lot of fuel instantly on top of being at WOT. This will give you a quick drop in pressure until the regulator in your gas tank notices and corrects for it. The short answer is no matter how good your pump is a retuenless system will always have a quick drop, then as long as the pump is stong it will recover.
The best solution is a stand-alone fuel system for the nitrous, which is why Dave designed one specificly for these cars.
