What can happen to your engine if a solenoid fails during a sprayed run?????????
Say a big shot like a 300 progressive with a timing tuner during a roll race.
I guess what I need to know is: Can you lose an engine with any kind of failure of the nitrous system during a run?
Are you asking if the nitrous or fuel solenoid fails can you hurt your motor? If the fuel solenoid fails you are probably going to hurt something. Not sure what would happen if just the nitrous one failed. I guess your motor would probably bog really bad because of all the fuel. You can run a FPSS to avoid these probs.
The Wet Hits:
The fuel noid failure (staying closed, or partially closed) on wet hits is the biggest problem, and one of the reasons I don't like progressive controllers, cause they beat the hell out of the noids. With one prog run equal to full season of normal runs. Any way, you'll go way lean and an ensuing melt down, or parts breakage from super high temps and clyinder pressures.
Now if the fuel noid sticks open, on a wet hit, normally nothing happens if caught right away. There are scenerios where the fuel/vapor could ignite and cause an intake back fire.
Now if the n2o noid sticks open on a wet hit, you could have catastrophic failure again. You'll go way lean and an ensuing melt down can occure.
Now if the n2o noid sticks closed on a wet hit, again you fill the intake up with fuel/vapors and back fires are possible; many reason that can set these back fires off.
The Dry Hits:
Ok, now the noid n2o noid sticks open on a dry hit, well nothing happens normally, if ya know the sign. When the additional n2o is added the MAF still registers this and adds fuel accordingly. Then you'll see your rpms come up and stay up. When you open your bottle prior to a run, if the idle comes up a tad, or gets rough you have a leaking noid. If it sticks open on a run your rpms will not come down when letting off the gas.
Now if the noid sticks closed on a dry hit, what happens, nothing.
Robert
The Dry Hits:
Robert
Originally Posted by Robert56
The Wet Hits:
The Dry Hits:
Robert
The Dry Hits:
Robert
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
Restricted User
Well either way, it's not good if something gets stuck open...but thats all the fun of running with spray...you take the risk...but like everyone said, Nitrous Selenoid is stuck open, you break. Unfortuately, if you run and your fuel selenoid doesn't open, again that a problem....
I guess I should have mentioned I will not have a MAF, going SD tune, 105mm TB and a sheet metal intake. On top of a 454ci.
I must use a prog controller, I'll never get traction if it just hits all at once.
Can a dry shot be done that big, 300 shot progressively controlled with no MAF?
The question is than:
Is there any system out there, regardless of the cost, that will detect any type of negative failure and just save your engine by shutting everything or part of the system down?
If there is I'll get it, if there isn't.............**** nitrous. I'm not gonna lose a brand new $18,000 engine. I'll just go single turbo.
Thanks.
Thanks.
The wet hit, unless you have a rich/lean controller to shut ya down, likely you will not know until something happens, read: breakage, meltdown.
Robert
The only way a dry nitrous system works is with a MAF- The MAF detects all the oxygen coming in and adds fuel accordingly, that's how it works. Without a maf you'de just be shooting nitrous into the engine with no accomadating fuel, making it run extraordinarily lean and prob. breaking something.
I can do a DP shot without a MAF though.
I just need to know if there's something out there that can 100% protect the engine in the event a component fails in the nitrous system.
OWN3D BY MY PROF!
https://ls1tech.com/forums/nitrous-oxide/548010-speed-density-nitrous.html
There are ways to run dry without a MAF, but why is the real question, unless going mega hit?
Check with the vendors as there are afew products that will cut the n2o if going lean or rich, a couple are NX/FJO, and Dyno Tune.
If there's a system that will save the day if anything fails, than I have found what I'm looking for. I'd like a system that will shut off the N20 and the FUEL at the same time if there's any problem.
Thanks.
Originally Posted by Quickin
I don't want to use a dry shot. I want to use a direct port 300.
Thanks.
Thanks.
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
Robert
The first part of statement was directed to another post. The second part is relevant to your wants/needs and add HSW to the list. Check each site out and you'll find what ya want, except the HSW product, not on site yet, but a current thread all about it. Allthough a product that will save the day in all cases, not going to happen, so you may want to rethink drag racing as a hobby, cause is isn't a matter of breaking, but a matter of when.
Robert
Robert
I'll look into the systems and see what I come up with, thanks.
