Auto timing retard on the Spray?
Old May 23, 2003 | 04:14 PM
Hit Man X's Avatar
Default Auto timing retard on the Spray?
Well back years ago I used an MSD 6AL w/ a digital multi retard for pulling timing while on the spray but let me have full timing while on the motor the rest of the time.
So, does anything like this exist for the LS1 nitrous kits?
Thanks!
Old May 23, 2003 | 04:52 PM
383LQ4SS's Avatar
Default Re: Auto timing retard on the Spray?
Timing Tuner by Ramchargers. They are a sponsor with a link on the right>>>>
I used one to get my HP #s and it works like a charm...Its currently at Ramchargers getting a new upgrade. They are going to make the integral window switch more programmable on the shutoff RPM. Excellent product....and in reality...the ONLY product for LS1s.
Old May 23, 2003 | 04:58 PM
Hit Man X's Avatar
Sounds exactly what I am looking for. Do you know if this will work with multistage setups also?
Old May 23, 2003 | 05:18 PM
383LQ4SS's Avatar
well..you can set your timing while off the juice and then there is one stage retard for while spraying. Its easy enough to get to and change...i guess you could just set your normal timing down a few degrees on a nitrous run and then use the regular nitrous retard function for the second stage. Thats what I did. But there isnt specifically a two stage timing functon....just one.
Old May 23, 2003 | 05:23 PM
Hit Man X's Avatar
Well heck if I do run a two stage (75 dry, 125 wet), couldn't I just pull all the timing needed for both stages with the single retard function.
Like if each stage needed 3* retarded, I could pull 6* total(all at once) with the controller?
Old May 23, 2003 | 05:59 PM
383LQ4SS's Avatar
yeah...you could.
Old Jun 8, 2003 | 09:45 PM
muscleSS00's Avatar
WHAT WAS THE PART CALLED YOU USED FOR N2O
Old Jun 8, 2003 | 09:46 PM
muscleSS00's Avatar
FROM RAMCHARGERS THAT IS
Old Jun 8, 2003 | 11:03 PM
Hit Man X's Avatar
www.ramchargers.com sells them. It is listed on their website.
Old Jun 9, 2003 | 08:32 PM
B18B1LS1's Avatar
Any idea if they can take the old design and upgrade it for a few bucks for us?
Jeffrey
Old Jun 10, 2003 | 11:21 AM
mobius's Avatar
b18 what mods do you have? are you running a stall? slicks?
thanks
Old Jun 10, 2003 | 07:44 PM
B18B1LS1's Avatar
My mods are K&N FIPK (power robber), Hooker longtubes, ORY, TP4400, Moser 12-bolt w/ 4.30's, MAFT, Ramchargers timing tuner, RT catback w/ cutout or bullets straight off the headers (depends on my mood), NOS 5177 tweaked a little, NOS wet kit w/ independant fuel system, T-Rex inline fuel pump, HPP3, Pro Stars w/ 30" Hoosiers, and I think that's about it. There maybe some other little things I'm forgetting.
Jeffrey
