Any pics of 2 bottles mounted in a f-body?
Just like the title says, looking for any pictures of an F-body with 2 bottles mounted in them. Did a search but no luck yet, the only one I found was a guy with 2 -10 pounders on the spare tire well.
Thanks in advance,
Rob
Thanks in advance,
Rob
Hahhaa, thanks, they look like two rocket packs back there!!!! ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Big crowd pleaser, but it really helped a lot with pressure loss throughout the run on a big shot! On 1 15lb bottle I would go from 1150/1200 - under 900, after I put the 2 together, it drops from 1150/1200 to 1050/1100.
check out one of the mods setup
https://ls1tech.com/forums/nitrous-oxide/669466-can-t-decide-where-put.html
Ok question for all you with them mounted like that, what did you guys do for blow down tubes??? I was going to run a flexible line from the bottle then drill a hole in my floorboard and mount a fitting there so I can screw the line onto the fitting but the fitting would vent to the outside.
How did you guys run your blowdown tubes?
