safe to spray?
Old Nov 21, 2007 | 11:56 PM
chevy0128's Avatar
Default safe to spray?
ok i am pissed because i am getting a spark knock past 4500 rpm on a basicly stock motor with bolt ons. i just put a tnt f1 100 wet shot on there and i cant spray till i fix it!!! i alway put 93 octane and synthetic oil . it should do this!! it stops if i put like 100+ octane but it shouldt be like this ....so how do i fix it so i can spray and also would it to be safe to spray if i have the 100+ racing fuel or do you think this would just bring the spark knock back because of all the added pressure.
Old Nov 22, 2007 | 12:11 AM
Nitro Dave's Nitrous Outlet's Avatar
Sounds like you need to get a tune?
You will probley need to pull some timming.
What is your airfuel?
What is your timming?
What spark plugs are you using?
Dave
Old Nov 22, 2007 | 12:18 AM
LSXS10's Avatar
DETONATION= busted pistons not cool
Old Nov 22, 2007 | 12:34 AM
chevy0128's Avatar
its all stock mapped. i have the ngk tr6.. if i have to pull some timing wont i loose alot of power tho
Old Nov 22, 2007 | 12:37 AM
Not really. Normaly depending on how much you pull maybe a couple of HP. Are you sure you are not running lean?
Dave
Old Nov 22, 2007 | 12:42 AM
chevy0128's Avatar
no i am not sure i have not had a tune. just a couple of bolt on installed n the tnt kit which i havent used. i would be willing to spend the 350 bucks for the tune but only if it would fix it for sure. also what do you clean the maf with
Old Nov 22, 2007 | 11:48 PM
AR15 guy's Avatar
Where are you located? If you are anywhere near KY a guy in Ashland does amazing work for CHEAP. Most of my buddies have had his tunes with great results.
Old Nov 23, 2007 | 01:01 AM
Zero4488's Avatar
Restricted User
Spend the money and get a tune....it's the right thing to do....
Old Nov 23, 2007 | 09:13 PM
chevy0128's Avatar
but if the tune doesnt fix the knock i am basicly just down 400 bucks
Old Nov 24, 2007 | 12:23 AM
NSTY WS6's Avatar
If your that worried about 400 bucks in this hobby, you've gone down the wrong road!
A tune is probably going to be the single best thing you could do to your car. Without one at this point, your working on putting holes in your pistons. If the car has never had one, you'll pick up from a motor tune. then they'll probably take 4 degrees of timing out for a 100 shot. Theres a good chance your car will be faster with the "nitrous tune"...
You also need someone to make sure the car is not running too lean on the bottle... which would be the tuner....
Old Nov 24, 2007 | 12:12 PM
Rick@HSW's Avatar
you really should get that thing on a dyno and see what its doin. $400 bucks is a small price to pay for piece of mind. like the old saying goes...pay me $400 now or pay me $5K+ later when something serious happens. find a sponsor near you and talk to them...most basic bolt on tunes now a days are around $200 bucks or so. goodluck with it.
Old Nov 24, 2007 | 06:30 PM
Blindmelon's Avatar
I always run a wide-band gauge & keep my A/F at 11.7 or real close also went with TR6 plugs but now running one step colder on a 2 stage 100 hp & stage two 50 hp. I also have a MSD Timing Twister so you can adjust timing plus or minus for motor runs & it is adjustable to pull what ever timing you want with nitrous activation. I always use NX nitrous octane booster. The above will keep you safe. Cut corners & it will cost you. I also run 2 bottles into a y-fitting 6 an to the front with adjustable bottle heaters so my pressure stays stable every run at about 1050 psi. LOL
Old Nov 24, 2007 | 11:40 PM
The tune will fix the spark knock unless you have a bad knock sensor.
If you have a bad knock sensor you would be getting spark knock on NA as well.
Dave
Old Nov 25, 2007 | 03:33 AM
chevy0128's Avatar
what is NA.. and yes i no 400 is a small price to pay ..but the people that installed the kit made it seem like the 1500 i already did pay would have me ready to spray. I guess i was kinda just trigger happy. Do any of you kn ow of a good sponser in the san antonio or houston area
Old Nov 25, 2007 | 08:34 PM
88zukon36s's Avatar
give mike at G-Force a call he will take good care you. He did great work with my tune, I will be getting a nitrous tune soon.
Old Nov 25, 2007 | 10:23 PM
NSTY WS6's Avatar
Naturally Aspirated.... otherwise known as motor only...
1500 bucks...
Is that normal? Guess it depends on what all you get, but, damn! I cringe at all the labor charges tho too... Goodness!
Go down the sponsors list, you'll find a few in texas, you could post in the tuning/diagnostics forum too, lots of guys on the board tune or will know where you could go...
