AFR Safety Switch discussion
Anyways, just for those who have not thought out their tune, you may want to consider how your car responds to this, in your planning of what the cutoffs are and how useful they will be.
I plan on setting my AFR enable switch to 10-12 for the system to function; if you look at the above log that pull did not reach 12.0 until just under 4000 RPM...My Dry shot fires at 2800 RPM
No problem for EFI Live and COS 5 , the custom tune will be active with the arm switch so I will be in the Cutoff window, however those running stock tunes, it may be an issue, if you have to adjust it to say 10-14 for it to fire correctly for your window, how effective is that for maintaining the 10-12 AFR? Based on the above log, I would probably need to set the AFR to around 10-13.75 or so for it to fire as needed.
Thought I would throw that out there for discussion.
Jim
Setting it to 14 or so would keep it above your lean spike (which is very small compared to most) It would definetly offer you some protection but not ideal.
Vinny
I think alot of buyers of AFR safety's (not brand specific), may not realize the cause and effects side of tuning and running a AFR Safety Switch. I am speculating a high rate of return, and them getting a bad rap (kinda like FPSS because they are not set correctly) just from not understanding tuning.
Robert
Robert
Short timing here in Singapore...Can't wait to get home and play with the tune and the Gauge, as well, still changing things up on my setup!
