Nitrous Hesitation Between Shifts
What do you have the window switch set at?
What are you shifting at?
Are you lifting to shift or a full power shift?
All of these will vary the delay. I have zero delay as my kit never shuts off from launch to finish line. 3500 stall, 3000 on, 7000 off, 7200 rev limiter, 6800 shift point, my foot never leaves the floor board.
Robert
sounds like you have a few things going on....
1) your kit shuts off @ 6
2) you shift @ 6200
3) full lift on shifts
4) drive by wire TB blade delay compared to pedal location.
For a M6 I would set the off point to the shift point or higher....if you are lifting to shift you will not be spraying through the new gear engagement.
When mine was still a T56 I used the nitrous off point as a "shift light"....
2) you shift @ 6200
