Teflon Sealant??
Old Jan 28, 2008 | 10:53 AM
Bill Bowling's Avatar
Default Teflon Sealant??
Started puting together my fuel gage sender and they say use Teflon sealant, not teflon tape. I went to a number of places and no one has anything called teflon sealant. I have some thread sealant. Is that the same?
Thanks,
Bill
Old Jan 28, 2008 | 10:57 AM
2002t/a06's Avatar
i think it will work fine??
Old Jan 28, 2008 | 11:02 AM
MetallicaMatt's Avatar
Napa or Advanced should carry it. Its Teflon paste.
Tape will work fine, just be VERY careful not to get near the end of the threads b/c you could get some tape in the line...clog a selenoid, etc etc bad things etc etc
Old Jan 28, 2008 | 11:05 AM
Advanced did not have it. I might try Napa. That is about the only one I did not try- it farther away.
Thanks,
Bill
Old Jan 28, 2008 | 11:12 AM
jmill96Z's Avatar
Any hardware store will carry the paste. Just look in the plumbing section.
Old Jan 28, 2008 | 11:26 AM
Plumbing/glue/sealants etc
Old Jan 28, 2008 | 11:31 AM
Mike@HSW's Avatar
I would think just about any hardware store will have teflon paste, do not use teflon tape, you dont want that getting pulled into your line.
Old Jan 28, 2008 | 02:07 PM
mrdragster1970's Avatar
6 & 8 Second Club
I use the teflon plumbing paste also.
Old Jan 28, 2008 | 02:31 PM
jmill96Z's Avatar
I still use the tape. It works great as long as you install it correctly
Old Jan 28, 2008 | 03:43 PM
myfast70's Avatar
Or you can just use Red Loc-Tite. That's what came with some of my NX stuff and I used it on all of my pipe fittings and have not had any issues. It can also be removed if need be. No chance of the teflon paste drying up and clogging a nozzle or jet.
Old Jan 28, 2008 | 04:06 PM
I just checked and I have a new Red Loc-Tite stick. I think I will give it a try.
Thanks,
Bill
Old Jan 28, 2008 | 04:23 PM
myfast70's Avatar
Thanks,
Bill
A little dab will go a long way! Don't go crazy with it.
Old Jan 28, 2008 | 10:56 PM
bigsticksupra's Avatar
Permatex makes the liquid teflon thread sealant. you can get it at pepboys and kragens.
Old Jan 28, 2008 | 11:02 PM
Nitro Dave's Nitrous Outlet's Avatar
Like suggested above. A hardware store is the best place to go. It will be in the plumbing section.
Ace Hardware
Home Depot
Lowes
Old Mar 15, 2008 | 12:03 PM
tamikews6's Avatar
If you don't want to go to the store order it here.
http://www.amazon.com/s/ref=sr_nr_i_...te%2Ci%3Atools
Old Mar 15, 2008 | 12:39 PM
I got some at Home Depot.
Thanks,
Bill
Old Mar 15, 2008 | 01:40 PM
Robert56's Avatar
Thanks,
Bill
Be careful using the red lock tights. it's designed for stud locking and not really meant as a removable type sealant. A better option is to use Blue lock tight as it's meant as a sealant that can easily be disassembled. the red can cause problems, esp with alum and yes I use both on a daily basis, in many applications, in the Maritime industry. my favorite for home use is Blue 430 IIRC, as it's designed to still seal properly even when contaminated with oil, most wont work well if not totally clean. Actually, any soft seal that's used on pipe fittings will do. Teflon paste comes in many brands and names, and at work we use Seals Pipe.
Robert
