Nitrous on an LT1
Old Mar 19, 2008 | 11:47 PM
LS1 Life's Avatar
Question Nitrous on an LT1
Alright so i got a guy that wants to do a 100 shot to a stock LT1 97 Z28....
What advice can be given to him? Im going to have him read this so post openly.
Old Mar 19, 2008 | 11:53 PM
LT1-DAN's Avatar
How many miles on the engine, and the condition of the engine?
Old Mar 20, 2008 | 08:49 AM
LS1 Life's Avatar
im thinkin above 70k. but id have to check
Old Mar 20, 2008 | 08:53 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
The most important thing is simple, spend the extra money on safety equipment: window switch, wot switch, fuel pressure safety switch. Spray the first time either on a dyno or with monitoring equipment of some sort to verify a/f and that there is not too much timing advance.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Mar 20, 2008 | 01:36 PM
Formula96's Avatar
safty is the key, tell him not to spray 150 wet with just colder plugs, **** makes poping sounds and then smoke starts coming out...
Old Mar 20, 2008 | 02:05 PM
starbucks's Avatar
he might wanna do a compresion test on the all of the cylnders(spelled that wrong i think) to make sure the motor is healthy enough to spray.
Old Mar 20, 2008 | 02:19 PM
Formula96's Avatar
^^^ maybe that was my problem 175,XXX+ miles
Old Mar 20, 2008 | 06:47 PM
LS1 Life's Avatar
you guys really need to read....
i said its a 100 shot not a 150 wet shot.
To any random idiot, any car is good enough for nitrous as long as it runs.
W/e the crap is never touchin any of my cars.
Old Mar 20, 2008 | 08:56 PM
BOLO's Avatar
NO. You mean aslong as it's in good TUNE/"HEALTH"!
Old Mar 20, 2008 | 09:23 PM
donkey mule's Avatar
Wow! It sounds like you dont know much about nitrous and Lt1's. 1st of all unless your friend plans on doing more mods the way of choice for Lt1's is a wet shot. If the Lt1 is in good running shape it should take a 150 wet shot if done properly. I know of people running 175+ rwhp shots on stock blocks and have been doing fine. The key is doing research and knowing what you are doing before you do it. For a 100 shot I would recomend ngk tr6 plugs, 1 - 2 degrees timing pulled and your basic safety equipment.
Old Mar 20, 2008 | 09:24 PM
Formula96's Avatar
I read your origanal post well enough. The funny thing about nitrous is that it does have a funny effect on people. I started just with a 75 shot, and that was all i was gonna do. But then it just wasn't enough. So i upped it. You asked for advice, i gave mine, if you don't like it, just shut the hell up and don't ask for advice.... OR try telling your buddy to do a search on the subject. PLENTY of info on nitrous on this site.
Old Mar 20, 2008 | 11:27 PM
LS1 Life's Avatar
... im not gonna debate with you bud. But out of curiosity, if you didnt notice a difference with a 75 shot why didnt you just do motor mods? Is there really a huge difference with a bigger shot? Im sure its noticeable at like 200+ but... how much do you need to put through the block before you can notice?
I personally think nitrous is the worst thing for a motor but its just an opinion.
ill let him read all the posts, thanks for the info.
Old Mar 21, 2008 | 06:53 AM
Z-RATED94's Avatar
Any "random idiot" would know there's a difference between a car that runs, and an engine that is healthy enough to run a small shot of nitrous.
Maybe the person that owns this car should find someone that is a little more knowledgeable in this area than just a "representative".
Old Mar 21, 2008 | 09:51 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
Some very good advice has been given in this thread along with alot of hearsay information.
Nitrous can be ran safely as long as the standard precautions are taken.
1) Compression test
2) Safety features
3) Tuning
A stock internal LT1 can take up to a 150 shot as long as these steps are taken.
Feel free to have your friend call/email me if he has any questions.
Old Mar 21, 2008 | 10:24 AM
DopdBrd's Avatar
I noticed a difference with a 75 shot. And I noticed a hell of a difference with a 150 shot. Took 1.34 seconds off my quarter mile.
Did you come on here hoping that we would talk him out of nitrous? I mean seriously man. Nitrous is as safe as you want it to be. If you have all the safety equipment and tune the motor right there is no reason why you cannot run nitrous safely. I ran a 150 shot on my STOCK LT1 ALL THE TIME. With no problems whatsoever. I plan on spraying a 150 shot on my 400 RWHP motor and hope to run low 11's or high 10's.
Don't knock something you clearly know nothing about.
Old Mar 21, 2008 | 05:05 PM
Formula96's Avatar
i did notice the 75 shot, I just knew that i had the abillity to do more, so i did.
Old Mar 21, 2008 | 05:10 PM
LS2TA's Avatar
I Think Its Safe I Heard Lt1's Can Hold Alot I Had One But Never Sprayed On It
Old Mar 21, 2008 | 05:24 PM
kierstyn's Avatar
My lt1 bolt-on car loves a 100 shot it picked up alot with it no timing pulled and ngk tr6s. Its one of the best things i have ever done for the $. Like was said above as long as its used right you will be ok. I have seen a 200 shot sprayed on a stock short block over and over again. I dont have the ***** to spray that much but his car makes killer power.
Old Mar 22, 2008 | 01:47 PM
SEXICAN's Avatar
i did it with a nitro dave kit 150 wet, its boltons,racetronix kit, mallory box, fp safety switch, **** runs good with 160,000 miles.
Old Mar 23, 2008 | 12:07 PM
kahunaking's Avatar
My 96k mile lt1 loved the 100 shot. And just for the record we put nitrous on my brothers 5.0 mustang with 190k miles on it and ran a 100 shot through it with no problems.
