Best set up for 94 Lt1 w/ full bolt on?
I would go with Nitrous outlet plate system if you can afford it or a harris speed works kit if you are tight on money. Im speaking from experience. I would get it tuned or get a wideband and run a 100 shot, make sure you get all the things that go with a good nitrous system FPSS, WOT switch, window switch, heater, purge, timing retard, Walbro, Tr6 plugs. etc. The mallory 685 ignition box will be you best friend with nitrous as it includes many of those listed features in one. As always in a perfect world you would do a compression test prior to using nitrous but thats up to you. If the motor is in good shape and you do everything listed with no shortcuts the engine will live a long time. If its not in good shape Nitrous will point that out pretty quick. Im rolling with 154,xxx miles on my lt1 i have used 7 bottles at 100 shot and one at 150. My car runs great, and pulls pretty good on spray. Good luck to you
Iam Running The Nitrous Outlet Plate Kit. I dont have it sll together yet but i will soon and ill post my results. I did alot of research and that was the best thing i could find for what i was palning on doing and for the money!
As you can see by all the relys our LT1 plate system is hard to beat!
We have something for everones needs and budget. Give us a call and talk to one of our knowledgable technicians. we can help you figure out what best fits your needs and budget.
Dave
Dave
