Having traction issues, anyone care to step inside
AFR stayed between 11-12, I need to lean out the rich spike just a little. Spraying a single nozzle dry 150, I believe .063 jetting. Bottle pressure 1100psi What could be done about my traction in first? HPTuners can't really cycle my solenoid for me so I can't script a progressive shot. Should I look into a 2 stage with 100 and then 50 or vice versa to accommodate for 1st gear. Or do you think pulling air out of my ET Streets would make enough difference?
Aside from tires, I also have tubular LCA's and LCA relocation brackets set for the lowest hole. I want to think that its just the tire pressure thats keeping me from hooking in 1st.
i was spraying 150 on 18" nitto d/r's with 4.10 gears and a 6 speed and had no traction issues in first,window switch was at 3000
your m/t et streets should hook alot better and your a4 should hook better than my m6 did
what size rim?
Yep, usually referred to as drag radials. The ET Streets are a bias ply tire, closer to a real slick. You normally run more air in the DRs than the ETs. 20-22 hot is the range I run mine at for street, maybe a little lower (19/20) at the strip. I don't do a lot of normal street driving on them but run 28 when I do. They still hook better than street tires at that pressure but from a role not a dig.
Robert
