N2O baackfire = exploding hood.
Old Jul 1, 2008 | 05:07 PM
  #41
waterbug1999's Avatar
I just sprayed the car with a ~100 shot.. All was good and a/f was ~10.5 (a little rich). But, the pressure is still at ~1200 (it did hit 85* today, so maybe that why?) or so and wont go down. Knowing this, I changed me jettings..
Old Jul 1, 2008 | 06:03 PM
  #42
SScott's Avatar
The person taking the video has Parkinson's disease or something. Holly get a camera stand batman. Almost made me sick watching that.
Maybe a dumb question but are you sure it was caused by the nitrous and not just a bad hood?
Old Jul 1, 2008 | 06:06 PM
  #43
dochall22's Avatar
"Its a hood" - announcer
Old Jul 1, 2008 | 06:25 PM
  #44
Nitro Dave's Nitrous Outlet's Avatar
Is the bottle temperature up high. If so this may be why the bottle pressure is staying up high.
The jetting Nano is giving out is nothing more than a suggested starting point so keep in mind you still need to varify airfuel.
Sorry to see that hood get blown up like that. I know that was a grand down the drain..
Dave
Old Jul 1, 2008 | 06:26 PM
  #45
Nice looking car by the way..
Old Jul 1, 2008 | 08:29 PM
  #46
Dave
Yea, I new it was a starting point, and I am sure it was fine till the presure shot up to ~1300psi..
I put the jets sizes that I know is a little rich in today just in case the NANO spiked again.. It was consistent today, but was a little hot so maybe that explains the increased pressure today.
But, on that morning at the track, it was ~10:45am and ~70* outside. When I turned the bottle on it was ~950 and was good to go. In the ~5 sec. I was into it, it backfired then got back to the pits and saw the pressure at 1300psi..
Old Jul 1, 2008 | 08:55 PM
  #47
Wow. The pressure should not creep like that. Have you contacted TOm or Brad at Nano to see what they say?
Dave
Old Jul 1, 2008 | 10:34 PM
  #48
Robert56's Avatar
Originally Posted by waterbug1999
They are not changing the rec. psi, its suppose to regulate ~950 at all times. The only thing that is recommended is to take out ~20% less N20 or add ~20% on the fuel side to compensate.
I wonder why that is. seems if you were to run it at the nitrous manufactures rec pressure there would be no issues and thus no need for re-tuning. Am I missing something here? maybe they think the 950psi is the optimum pressure to run n2o at, as per NOS and hope that retuning won't be a down fall to most IE: cost. To me that would be a bitch. ok i just forked out X amount of dollars for my rather expensive nitrous tune, now I need to do it again. Not a good marketing move IMO, unless there is an underlying reason.
Robert
Old Jul 1, 2008 | 10:42 PM
  #49
Robert56's Avatar
Well, I got a PM from a nano rep. and they will be contacting me to see what can be done.. Today I tried to get the pressure down and it took ALOT of purging to even get into under 1100. But, at this point there is not much left. So, we are working on a solution. I would just watch the bottle pressure.
I would be careful here. you may be purging all your n2o out. If in fact your valve is stuck open like you think, to get the pressure down you have to start removing from the NANO bottle and to do that you have to get rid of the n2o first, as it's the NANO pressure your fighting not the n2o, unless your bottle is getting super hot all of a sudden (doubtfull). be careful of going really, really lean now. Hope you get it sorted out quickly.
Old Jul 2, 2008 | 09:17 AM
  #50
Robert
From what I understand why is... It is pushing the liquid up and out the noids and into the motor instead of the gas's that comes from using the bottle heater.
So, with it being liquid, it requires ~20% less N20 or just up the fuel to compensate.. But if you go up on the fuel side its a bigger shot then what you think.
Old Jul 2, 2008 | 09:33 AM
  #51
Ray@Nitrous Outlet
Guest
Posts: n/a
Old Jul 2, 2008 | 12:28 PM
  #52
Does a backfire come out the tail pipes?
Look at these pics I took from the video.
Old Jul 2, 2008 | 07:58 PM
  #53
Jake@EPP's Avatar
Does the car run fine? No loud valve train noise or rough idle. You quite possibly could have bent a valve from it, ANYTHING is possible.
Never seen a hood go whammy like that though.
Old Jul 2, 2008 | 08:15 PM
  #54
Robert56's Avatar
So then, we all need to know that a re-tune will be needed if running the NANO kit? If it requires 20% less n2o, then it seems it could be compensated for by lowering the pressure set point on the regulator. though that would likely be a crap shoot and prob be better just to re-tune and be safe. God I love learning n2o stuff, and anyone whom claims or tries to portray that they know it all, is a dumb azz, lol. thanks
Robert
Old Jul 2, 2008 | 09:36 PM
  #55
Well, nothing sounds messed up.... I have taken it for a spin and all seems to be good to go.
Old Jul 2, 2008 | 09:41 PM
  #56
Robert
Im not sure if we are on the same page here... Leave you N/A tune alone and leave that where you consider safe. Most people are about ~13.1 AF N/A.
Just do simple math with picking the jet sizes for the NANO shots.
Pretty much if you want to run a 100 shot NANO, just use the 75 shot N20 jet (whatever NX number that may be) and use the 100 fuel jet (whatever NX number that may be).
That a 25% decrease in N20, but it should be a safe start.
Old Jul 2, 2008 | 09:45 PM
  #57
I talked with the NANO rep today and they suspect the regulator got damaged during the N20 fill... So, I was told to unhook the NANO braided line from the check valve on the N20 bottle...
Old Jul 2, 2008 | 09:48 PM
  #58
SCOTT SS's Avatar
Im beginning to think the bottle pressure spiked and the noids got stuck open.Maybe the system was still spraying when you let off the throttle??Just a thought.
Old Jul 2, 2008 | 09:57 PM
  #59
Well, I had it WOT throttle till I saw the hood fly off.. I had both my cut outs open so I did not hear a damn thing, just saw the hood fly off. FYI, the foam around the seal (where the hood seals to the square opening) was all melted to ****.. I did not have my air filter in at the time so that why I did not have a fire.
Old Jul 2, 2008 | 10:22 PM
  #60
Robert
Robert, After reading your post in this thread I dont think you are understanding how the nano system works and where the bennifit is to having one. Here is a good write up to help you learn.
http://www.nitroustech.com/forums/showthread.php?t=155
Let me know if you have any questions. I will be happy to explain it to you.
Dave
