Purchasing Nitrous Kit
Old 07-01-2008, 08:57 AM
MYSTIC-1SC's Avatar
Default Purchasing Nitrous Kit
Well, I have decided to get a nitrous kit, and would like oppinions on what kits everyone likes and what they are running. I was thinking about getting the NOS brand wet plate kit, spraying 100 shot. Retails for around 700 dollars or a little less. Let me know what you guys think about this and what kind of times can be expected possibly. My current mods are Hooker long tubes, ory, slp loudmouth, slp flowpac, predator programmer and nitto drag radials.
Old 07-01-2008, 09:02 AM
Mike@HSW's Avatar
here is another option for you
http://www.harrisspeedworks.com/shop...cat=398&page=1
our plate is the only full 360 degree perimeter discharge plate and sells for a great price. I would recommend a bottle heater, FPSS and colder plugs at a minumum
Old 07-01-2008, 09:05 AM
Beer99C5's Avatar
There are serveral options now for plates.
Harris Speed Works, Nitrous Outlet, and NOS, each a little different in spray patterns and location of the the fittings for plumbing. Take a look at each and contact each vendor for more info.
Consider the other items as well Heater/Purge/Window Switch that is not part of a Standard kit.
LOL Mike beat me to it.
Jim
Old 07-01-2008, 10:11 AM
SuperSlow02's Avatar
If you want to see the HSW kit in person, let me know and ill drive the pile one of these nights. Deffiently a bad *** looking set up, quality parts, and easy to install.
Old 07-01-2008, 10:16 AM
krazy4's Avatar
My kit has a ton of different manufacturers parts mixed together.
For a full kit, I like Dynotune. Guys are very helpful.
Old 07-01-2008, 10:40 AM
Chris@NitroDaves
Guest
Posts: n/a
We offer the largest selection when it comes to nitrous systems and components. We offer Nitrous Outlet, Brand X, 860 Performance, NOS, ZEX, NX and much more.
If you are looking for a plate system with the highest flowing best designed components look not further than the nitrous Outlet plate system. There is not another plate system on the market that can out flow or out perform our system.
View Video on FQuick
Look how fast and hard the plate kits...No delays here
If you are looking for a heck of a deal and top flow is not a priority check out our special this month with the Brand X system and Nitrous Outlet plate conversion. This combo can flow up to 200HP. The solenoids are not as big and high flowing as the Nitrous Outlet system however it will still flow up to 200hp and the solenoids operate under pressures and heat that some other budget brands will not.
If I can help in any way please let me know. Feel free to ask me any questions you have.
Also check out the specials we have going on
Summer Time Special
https://ls1tech.com/forums/nitrous-oxide/934999-nitrous-outlet-summer-time-specials.html
Killer Deals
https://ls1tech.com/forums/nitrous-oxide/946421-killer-4th-july-deals-part-1-a.html
-Chris
Old 07-01-2008, 11:46 AM
Race your car!
JL ws-6's Avatar
Having the Nos plate, I can tell you a couple things. The kit is decent, comes with pretty much everything that you need as far as the actual nitrous kit goes.
Couple things that you will want, a purge kit. I know that the kit hits a TON harder when you can clear the line up to the solenoids. I'd get a fuel and nitrous pressure guage, so you can see where that stuff is (not that you really have a ton of time to look at it when you're making a run) and I would also highly suggest a window switch, and I would just do a racetronix fuel pump setup with a hotwire kit.
I have seen alot of people have problems with the Fuel pressure safety switch, so rather then go that route I would just put a fuel pump in the car so you have plenty of fuel for the power level you're at. IMO, having plenty of fuel system is way safer then a FPSS will ever be.
Don't spray under 3000 rpm and make sure the nitrous turns off before your rev limiter. I'd ditch the diablo handheld and get someone to do a real tune for the car.
Old 07-01-2008, 12:54 PM
MYSTIC-1SC's Avatar
keep the advice and suggestions coming
Old 07-01-2008, 03:50 PM
MYSTIC-1SC's Avatar
any pics of HSW plate setup installed
Old 07-01-2008, 05:12 PM
black01_WS6's Avatar
I would also suggest a good wideband to keep in the car, it helps for tuning and also at the track. look at the innovate as they are some of the best.
Since you are just getting this together look into the trick perfomance guages as they are pretty badass and work very well.
Old 07-01-2008, 05:26 PM
Nitro Dave's Nitrous Outlet's Avatar
Here are some install pics of our products..
http://www.nitrousoutlet.com/customerCars/index.asp
Old 07-01-2008, 07:41 PM
you dont pay any attention lol
Old 07-01-2008, 08:56 PM
01SuperSport's Avatar
I've always liked the TNT kit and am planning to buy it soon.
Old 07-01-2008, 09:05 PM
MYSTIC-1SC's Avatar
my bad superslow, you'll have to come out some time
Old 07-01-2008, 09:26 PM
ill be out this thursday buying wedding crap...yippie, anyways heather gave me a free pass to come out and play. So ill be at sonic
Old 07-01-2008, 10:33 PM
MYSTIC-1SC's Avatar
cool, i'll try to make it up there, oh and if you would don't let the word out. Cause i've already made a purchase
Old 07-01-2008, 10:56 PM
which kit did ya get?
Old 07-01-2008, 11:04 PM
95 Z28's Avatar
+1 for HSW's plate kit. I love mine. Quality parts, easy to set up, works flawlessly, and looks bad ***. I'll try to get a pic.
Old 07-02-2008, 08:03 AM
MYSTIC-1SC's Avatar
the HSW plate kit
Old 07-02-2008, 11:35 AM
you wont regret it, Ill PM you my number, got some guys coming down from marble hill that want to play.
