One Switch for 2/3 stages?
Position 1 50 shot Dry
Position 2 100 shot wet plate
Position 3 150 shot (50 and 100 both on)
or will P1/2 activate both kits due to the wireing on P3?
Where should I put the dry Nozzel?
1. You can use a "center off" toggle switch (on off on)would be the easiest. This assumes you have a separate "system on" switch. The the toggle switch center position could be the 50 shot, up would be the 100 shot, and down would be both. You would need one relay and one diode to operate all of it since you have pins 87 and 87a to do opposite actions.
2. Use a rotary switch like Beer uses. You'd need two relays, and one diode.
If you decide to go this route, and need help with the schematic, pm me.
Can i have up be 50 center be 100 and down both?
I may need to start stocking a few of those switches, That would free up a bunch of space on some panels!
Todd post one of them there electrical diagram thingys you do there I may convert mine to a rotary switch and add the BAP to the panel (wired to the arm switches through diodes now)...
I think I am suffering from obsessive compelsive panel upgrade disorder...
Diagram one shows the rotary switch method. One pole, 3 positions.
Diagram two shows the "center off" toggle with the Center position being the 100 shot, the Up position being the 50 shot, and Down position being BOTH.
K1 and K2 are your existing relays. SW1 (diagram 2) is your "Master Arm" switch.
But the diodes are backwards, no power will flow through the cathode unless your using Zener diodes.
