Has Anyone Added A Nano System Without Rejetting?
Just wondering if anyone has ever added a nano or pusher system without rejetting to see if rejetting is actually needed. I run a zex 150 shot on my ls1 vette and it seems to already run really rich with the zex recommended jetting. Thanks ahead for any help.
Thanks guys for the info. The only reason that im asking is because I love the way that my car runs on the 150 shot and dont want to lose any power by going down to the 125 shot although nano say's that it will actually make 150 h.p. with the pusher system installed. But Im just not sure if it will and was hoping that someone has done some dyno runs to back up what nano is claiming. Thanks again for all the help.
I didn't change my jetting with the NANO and my air/fuel is the same 11.5 or so on the wideband as it is with a full bottle at 1050psi. My ETs didn't change either. I was hoping for a bit ot ET reduction. But, NANO's value to me is the elimination of the bottle heater and 1050 psi each time I open the bottle for consistancy.
Odds are you will need to rejet the system. You will still make the same HP if not more. Here is a tech article to help you understand how it works.
http://www.nitroustech.com/forums/showthread.php?t=155
Dave
Dave
Dave
Dave
See I was told that the little noids in the purple box wouldnt flow more then a 150 shot. So I could keep the 150 pill in and just up the fuel by 20% and add the nano system? Will this increase the shot from 150 to 180h.p hit being that it claims to produce a 20% more h.p. gain ? I was always under the impression that the only reason why it made the extra power is because the pressure. Do you think that my stock c5 can handle the hit if I just up the fuel side. Do you have any nano systems in stock? I do run tr6's. Also what do you recommend the plugs to be gapped at for this size of a shot? Thanks for all your help.
During the run the pressure will drop, even bigger drop the bigger the shot. So since the pressure doesn't drop you are getting more nitrous flowing into the motor during the run. That's why you need to use a bigger fuel jet so it doesn't lean out on the big end. For those with a standalone fuel system you can also adjust the fuel pressure up to compensate.
