Nitrous Wiring ? (did a Search)
I need a wiring diagram for a 92mm plate kit for nitro dave, with a dynotune purge, and a fjo contoller. I will be using one switch to arm the kit, and a push button when the kit is armed to purge. Does anyone think they can help me out?
You really don't want to run that much current through a switch, but it you want to.. go ahead. The switch may get hot. For short bursts, it should be ok. Use a high current switch (5-15a)
BTW, you need to ground the purge noid. I left it off the first schematic.
