1983 Honda 250R 3-Wheeler ATC
Runs. New piston and rings, barely 4 hours on them.
See video of it running here:
http://www.youtube.com/watch?v=WUJjL92tmgE
Located central Indiana (Kokomo area).
Frame has been powdercoated. Gas Tank needs pulled & painted. Newer plastics (black) and seat cover. Has twist throttle and DG exhaust. Rear tires are almost new (80%), and front has 60% left. All hold air.
Rear brakes need bled, tends to leak pressure while sitting long periods. Front brake works OK.
Headlight is from a 350X. I haven't the eletrical know-how to reduce the voltage for this 2 cylce trike. Bulbs keep burning on high revs.
First $900 takes her home. Will consider trades
