Northwest Members WA, OR, ID, MT, WY, SD, ND
Orygun guys?
Old 10-06-2011, 10:27 PM
  #6741
tmoney223's Avatar
You would smoke them, well not by much but you would beat one.. I just don't see spending almost a 1,000 dollars on cams to gain 30-40 whp!.. Hell the new boss has better cams, ported heads and intake and they only got it to 445 or so. Really? Or are they just saying that like what the SS LS1 put out stock, and we all know that's not true.
Old 10-06-2011, 10:45 PM
  #6742
SalvageZ28's Avatar
Mikes is over the axle.
Old 10-06-2011, 10:47 PM
  #6743
SalvageZ28's Avatar
I have run a few new 5.0's already=) Spanked everyone so far=)
Old 10-06-2011, 11:03 PM
  #6744
tmoney223's Avatar
But is it a single?
Don't they weigh more as well then the new Camaro? I know the New SS is a pig..lol
Old 10-06-2011, 11:14 PM
  #6745
Rockin C Racing's Avatar
Wrong. Mike's exhaust ends before the axle and has elbows on the ends aiming it towards the rear tire to help disapate the noise for running at PIR.
Old 10-06-2011, 11:18 PM
  #6746
tmoney223's Avatar
That's what I thought! So he can stay under the DB. I remember him saying that a while back.
Old 10-06-2011, 11:41 PM
  #6747
02sslayer's Avatar
i saw his vid and im pretty sure it goes all the way out the back. ill have to watch the vid again tho...mike told me he thought dual 3 could be run out the back
Old 10-06-2011, 11:50 PM
  #6748
tmoney223's Avatar
You can go under the axles as long as you don't go jumping your car..lol... That's what I was going to do but went the 2.5 route.
Old 10-06-2011, 11:59 PM
  #6749
02sslayer's Avatar
under the axle looks pretty good too
Old 10-07-2011, 12:18 AM
  #6750
zlicious94's Avatar
The new ZL1 camaro is faster than a c6 z06 on the nurenberg or whatever the **** they call that track! Just read that and couldnt believe it!
Old 10-07-2011, 12:45 AM
  #6751
Tyler_LS1's Avatar
I figured cause I remember seeing it
Old 10-07-2011, 12:52 AM
  #6752
Tyler_LS1's Avatar
if your concerned about HP just run 2.5" duals out the back so it fits nice and have dual cutouts right at the collector, best of both worlds.
cause 3" true duals wont make much of a difference unless your making big power, thats a lot of pipe.
Old 10-07-2011, 02:00 AM
  #6753
SalvageZ28's Avatar
Nope=) its over the axle. see
http://youtu.be/OWJczGEm80E
Old 10-07-2011, 02:02 AM
  #6754
SalvageZ28's Avatar
But is it a single?
No i think the new 5.0 is a lil lighter then the camaro
Old 10-07-2011, 09:32 AM
  #6755
Sorry I can't see the vid at work. But I'm guessing that is an earlier video. If I recall correctly he had 2.5" over the axle when he had the LS1. With his current setup the 3" ends before the axle.
Old 10-07-2011, 10:16 AM
  #6756
Tyler_LS1's Avatar
Ya I saw his car last yr or the yr before and it was dumped with a turn down towards the pass side rear tire
I remember seeing a post or thread he put up showing his setup a while back
Old 10-07-2011, 10:24 AM
  #6757
02sslayer's Avatar
his dual setup was dumped at the axle the 4" goes all the way back
Old 10-07-2011, 10:30 AM
  #6758
02sslayer's Avatar
nurenbergerererrangrungkrout is the correct spelling
Old 10-07-2011, 11:27 AM
  #6759
Mikey 97Z M6's Avatar
My old exhaust setup was dual 3" dumped before the axle. The new exhaust I made last year is a single 4" over the axle into a single 4" Dyantech Splitflow muffler. Quieter than the duals and has just as much flow potential as dual 3". Possibly even better flow after you factor in the inside surface area resistance of the dual 3".
Mike
Old 10-07-2011, 11:41 AM
  #6760
Tongboy's Avatar
your WAY off, it's the nurburgerkingring
Quick Reply: Orygun guys?
