Northwest Members WA, OR, ID, MT, WY, SD, ND
Orygun guys?
Old 05-25-2012, 11:25 PM
  #7541
02sslayer's Avatar
I did sell the ls6. I'm hoping the intake is ok, but it's sounding like a plug or coil pack. My misfire is only on one cylinder I'm guessing I fouls one due to the intake and no retune, we will see tomorrow. IfI fix it tomorrow I'm gonna schedule a retune with tom, lower it get some drs and ride off into the sunset
Old 05-26-2012, 02:23 AM
  #7542
SalvageZ28's Avatar
Originally Posted by Rockin C Racing
I think he sold the LS6
hey cody i have that fuel tank ready for you if you still want it
Old 05-26-2012, 01:33 PM
  #7543
Mikey 97Z M6's Avatar
Just an FYI, an intake manifold swap isn't going to throw the tune off enough to foul a plug. You still have a MAF that will keep everything within "safe" operations. It could still be a fouled plug (plugs do go bad), but changing an intake manifold and then not getting it tuned will not cause a plug to foul. Not even close. Sounds to me like other issues though.
Try this. Set the car in neutral, running with parking brake on. Get a squirt bottle with water, rev the engine for a bit (3-4k rpms) enough to get the headers nice and hot. Start squirting each primary tube on each cylinder. The one that doesn't steam up much is the culprit. It will be quite evident if it's a bad misfire. If it's a random misfire this technique won't help much.
Another thing you can try is spraying a bit of starting fluid around the intake manifold while it's running. If the car is idling while doing this, then it revs up when you hit it with starting fluid, you have a vacuum leak at the manifold.
Mike
Old 05-26-2012, 01:52 PM
  #7544
Rockin C Racing's Avatar
Yeah. I'll connect with you next week sometime. I'm in Canada right now racing. Sunny and in the 80's. Gotta love it.
Old 05-26-2012, 02:48 PM
  #7545
02sslayer's Avatar
Thanks for the info mike, I will try spraying the water, I've allready checked for vacuume leaks. Another bit of info is my car is throwing a soft code cylinder 8 misfire so it is only doing this under a load. I'll change the plugs cuz its cheap lol. Of that don't work maybe take the intake apart
Old 05-27-2012, 02:27 AM
  #7546
Ryan 97 Ram Air T/A's Avatar
Shelby's lawsuit was a shame, but his involvement with Ford might have had something to do with it. They're hyper protective:
"Then we had the almost comedic situation of Ford threatening to sue Ferrari over alleged infringement of the former’s trademarked F150 brand (attached to its top-selling pick-up truck), the Scuderia having used the same designation for its 2011 Formula 1 car by way of recognising 150 years of Italian unification. Fortunately, sane heads prevailed quickly on this one, and Ferrari altered the name of its new challenger to F150th Italia."
Old 05-27-2012, 05:30 PM
  #7547
SsSteven's Avatar
ooh firehawk
http://portland.craigslist.org/mlt/cto/3034262326.html
Old 05-27-2012, 05:59 PM
  #7548
*02WS6TURK*'s Avatar
Originally Posted by SsSteven
I've seen that car all over. Pretty good shape for being parked outside.
Old 05-27-2012, 10:17 PM
  #7549
zlicious94's Avatar
Yeah that guy with the firehawk works at jim weston pontiac!
Old 05-28-2012, 03:21 AM
  #7550
MEGATRONSS's Avatar
If someone buys that fire hawk for even close to 14k I'm gonna be pissed....should buy my car instead
Old 05-28-2012, 09:28 AM
  #7551
I just offered him 17k to really **** you off.
Old 05-28-2012, 03:06 PM
  #7552
02sslayer's Avatar
so looks like the car has a mind of its own. everytime i have the scanner with me it runs awesome! then if i dont have the scanner it runs rough up top and flashes a code at me.
Old 05-28-2012, 03:07 PM
  #7553
02sslayer's Avatar
who in hell would want a pewter SS?
Old 05-28-2012, 11:22 PM
  #7554
welldonecj7's Avatar
Anyone used a crush sleeve elininator ? Starting to build a couple axles for the jeep and they offer one for my rear and I am thinking about going with one figured I would ask if you guys have had any experiance with them?
Old 05-28-2012, 11:42 PM
  #7555
02sslayer's Avatar
i dont even know what that is
Old 05-29-2012, 03:15 AM
  #7556
SalvageZ28's Avatar
Get your car tuned
Old 05-29-2012, 08:34 AM
  #7557
02sslayer's Avatar
That's exactly what I'm gonna do
  #7558
tmoney223's Avatar
Hey i just wanted to share what my best friend nolan did.
They saw a robbery going down at a convenient store and him and my other buddy saved the day..
http://m.kptv.com/w/video/video/62483905/
Old 05-29-2012, 10:21 AM
  #7559
SsSteven's Avatar
Ls6 Powered Jeep Cherokee
http://portland.craigslist.org/yam/cto/3040950919.html
Old 05-29-2012, 01:46 PM
  #7560
Yes, they are way more accurate than a crush sleeve. It basically uses the same principle as a 9" center section, using a collar and shims instead of relying on the amount of crush/preload from the sleeve.
Mike
Quick Reply: Orygun guys?
