Northwest Members WA, OR, ID, MT, WY, SD, ND
Failed Smog
Old Jan 21, 2009 | 08:23 AM
Vettestir's Avatar
Default Failed Smog
Ran the Camaro through smog and failed the "HC" at idle (261 should be >220)
I'm not sure were in Datamaster it gives me the proper cell to change in my Tunercats software? I just need to lean it out a little more to pass. Hey Ellis are you up yet.
Old Jan 21, 2009 | 01:09 PM
firehawk618's Avatar
Believe it or not, take out your air filter. If it just barely failed that will usualy do the trick.
Old Jan 21, 2009 | 01:18 PM
Vettestir's Avatar
It's a K&N and clean that shouldn't change anything at idle would it!! I only drove about 10 miles on the freeway and the engine temp was about 210. I could bump the temp up to 225 and drive the crap out of it to get it real hot. I would like to lean it out a little at idle just to be sure it passes.
Old Jan 21, 2009 | 01:44 PM
NVME's Avatar
A little alchohol will lean it out. Good luck.
Old Jan 21, 2009 | 02:29 PM
TwoFast4Lv's Avatar
Shoot me a call and come on buy
Old Jan 21, 2009 | 03:48 PM
Vettestir's Avatar
I'll call you when I get off work. Thanks
Old Jan 21, 2009 | 04:29 PM
krazzycowgirl's Avatar
gotta love living in Thurston county NO Emissions lol
Old Jan 21, 2009 | 04:43 PM
Vettestir's Avatar
But Tammy the car has to run to produce smog!!!
Old Jan 21, 2009 | 04:50 PM
wws699's Avatar
That made me chuckle!
Old Jan 21, 2009 | 05:09 PM
TwoFast4Lv's Avatar
BAMM!
Old Jan 21, 2009 | 05:29 PM
Vettestir's Avatar
I was just yanking her chain. I hope she gets that car running this year and out to the track.
Old Jan 21, 2009 | 06:02 PM
Yea thats why we have 7 other cars, two of them are VETTES lol.
just need minors for the iroc now, hopefully after dan gets back from spain I can kick his butt & make him do some work & we get it running for PINKS ALL OUT
Old Jan 26, 2009 | 12:25 PM
Vettestir's Avatar
Well took the car back thru Friday with a little leaner tune and a good 30 mile trip down I5. It failed again. Now I guess I'll have to put alcohol in and wire a manual switch up to the air pump and get this done. My log file shows it's lean so maybe my cats not working.
Old Jan 26, 2009 | 04:14 PM
maybe you need to add a hamster so your cats would work alittle harder for you bill lol,
Sorry had to Dan's not around tokeep me straight right now lol
Old Feb 4, 2009 | 01:31 PM
GT-347's Avatar
Bill, check your PM. I went thru the same thing with my daughter Marcie's car.
Old Feb 4, 2009 | 02:25 PM
Vettestir's Avatar
To follow up on the Thread I put 1 gal of alcohol to about 4 gal of gas and it passed. It droped the Hc from 260 to 210 and this was on the same machine 4 days apart. Does alcohol work yes if your real close to passing anyway. Maybe using less gas would help more but that did the trick.
Old Feb 4, 2009 | 03:26 PM
firechicken76's Avatar
what is this smog you people speak of? hehehe j/k mine should be legal, it passed in cali when the previous owner had it.
does removing all the emissions stuff make any gains in power? im adding headers soon, and will be removing cats, air pump, and probably ac. will i run into any code issues?
Old Feb 4, 2009 | 05:05 PM
TwoFast4Lv's Avatar
Glad to hear Bill!
Old Feb 4, 2009 | 07:09 PM
WAHUSKER's Avatar
SWEET! I may have to try that....I wonder if it quiets down blow off valves too?
