Northwest Members WA, OR, ID, MT, WY, SD, ND
Mark, Ellis, Sardog I need a little help
Old 03-14-2005 | 11:10 PM
Steve Goodwin's Avatar
Default Mark, Ellis, Sardog I need a little help
Okay I received the part to do the coolant bypass and hook up my polished throttle body. The pictures I've attached show the problem. The new throttle body when closed is at the six o-clock position, the old throttle body when closed is at the five o-clock position. When I hook up the throttle cable it of course only allows the throttle body return to the five o-clock position and unless I want to idle at 3000 RPM I've got a problem.
So what is the fix
BTW Mark I changed the Drivers side O2 Sensor, the outer cover was burned though. I believe I have this one zip tied away from the header.
Old 03-14-2005 | 11:11 PM
Picture is worth a thousand word right.
Attached Thumbnails Mark, Ellis, Sardog I need a little help-new-t.b..jpg   Mark, Ellis, Sardog I need a little help-old-t.b..jpg   Mark, Ellis, Sardog I need a little help-o2-sensor.jpg
Old 03-14-2005 | 11:16 PM
HitmanLSX's Avatar
pics?
edit: n/m helps to refresh before posting
Old 03-15-2005 | 12:26 AM
sardog46's Avatar
Steave I beleive that throttle body has the wrong throttle cam on it. The only way to fix it is to get a cam for you year, or get a throttle cable for that year cam. What year is your car?
Old 03-15-2005 | 01:06 AM
Nate_Taufer's Avatar
if it is stuck because of the cam and not resting on the throttle stop then you'll have to find a new tb cam.
Nate
Old 03-15-2005 | 01:17 AM
My car is a 2000. So he probably sent me back someone else's T.B..
Can I take the cam off my other T.B.? Wonder what year it is?
This T.B. story is becoming a real comedy, I originally sent it off to be ported before Thanksgiving. Getting go fast parts that look purdy sucks
Old 03-15-2005 | 01:23 AM
TwoFast4Lv's Avatar
Sorry Steve you have the wrong TB from the looks of it
Anyone else do them?
Old 03-15-2005 | 01:29 AM
sardog46's Avatar
Is it the orig throttle body? If it is you can just replace it. And it will work.
Old 03-15-2005 | 01:31 AM
sardog46's Avatar
You will be able to tell, just put the other throttle body in place and see if the cable works right if it does you can just swap the cams.
Old 03-15-2005 | 01:33 AM
Todd2001SS's Avatar
Tech Addict
Wait, I think there is an adjustment on the cable that you can tweak. It is that thick section it un snaps and it lets slack out ot in.
Old 03-15-2005 | 02:57 AM
NataSS Inc's Avatar
Looks like a 98 cam on that TB. If I remember right the 98's had a larger cam and it was designed to have a smoother roll in on the throttle.
Old 03-15-2005 | 08:48 AM
WAHUSKER's Avatar
I think my 2000 has the large cam on it. I'll have to look, but that is the problem - big tb cable cam vs small cam. And I think as Todd said there is an adjustment. I'll surf & see if I can find a post. Otherwise you have to swap the small one from Boyce's TB.
According to these pics, mine has that cam, so you must be able to make it work.
http://community.webshots.com/photo/...92743990qYfehS
http://community.webshots.com/photo/...34769529ygCzwQ
Want me to drive my car over so we can compare the setups? Friday night maybe?
Old 03-15-2005 | 09:44 AM
Mark,
I will be back in town Friday night so that works for me I'll make sure I have Pepsi & Mike's in stock.
I prefer not to change the cam out as the new one is polished to match the T.B..
Old 03-15-2005 | 10:14 AM
sardog46's Avatar
Mark,
That shoul be an easy task to acomplish steave, didn't you just get all the polishing equip.
I would rather have it no polished than to go back to a stock throttle body
Old 03-15-2005 | 12:43 PM
NICE!!!!!!!!! Actually both of the T.B.'s are ported and the red one has been done in epoxy and the cam is a silver epoxy. See building a show car and race car are very similar chasing that next 10th of a second and the perfectly polished cam & spring aren't all that different.
Old 03-15-2005 | 12:51 PM
HitmanLSX's Avatar
the polished cam and spring give you less friction in the air and thus faster cam movement and throttle response
Old 03-15-2005 | 01:00 PM
sardog46's Avatar
You Put all things in prespective steve. I like that.
Old 03-15-2005 | 01:13 PM
Jantzer98SS's Avatar
I sent a 00+ shaft as requested(oval). It turns out you really needed a 98/99 style round shaft. I don't know if you don't know what year your car is or if it's hybrid or what LOL, but I can polish up another one and send the round style. I emailed you back.
Scott
Old 03-15-2005 | 01:19 PM
WAHUSKER's Avatar
Hey Scott, how are you? I heard you had some problems. Sorry to see you're out of the game...loved your stuff!!! Hang in there man.
Old 03-15-2005 | 01:31 PM
I'm doing much better, thx. I had two close family members suddently lose health, one with cancer and another had brain surgery at the last second to save her life. They are both doing MUCH better. Except for breaking a drill bit off in my arm, I'm doing good. LOL. My oven is functional again and I'm almost back up to speed.
I let my family talk me into going back to work with them in construction/development so I will be payed better atleast. I will continue to do what I do but just take in a few projects here and there so I can enjoy it again instead of being backed up and having to deal with disgruntled customers. It just became more than one guy could deal with and my attempts at getting help didn't pan out. But I will be a bit more satisfied getting it back to where all my customers are happy. Because after all, I certainly wasn't doing it for the $.
Scott
