Double Clutching?
When i am racing i just barley tap the clutch, shift as fast as i can and keep the gas down. BUT................i would not recomend that method on the stock gearbox, as i found out last week.
Everyone explained it well enough - its just odd to think about nowdays.
Sardog! What were you thinking?! It sucks but my guess is the new gearbox will be virtually bullet proof
I will give you a hint the new one will only be 2 gears
Unless you are driving a Truck or NON Synchro'd trans that term is Obsolete
Even IF you're running a truck the term is still obsolete haha ! Slightly push the clutch in while popping it out of gear, let the clutch out and THEN push it into the next gear matching revs is how it's done now days. Lot's of people never use the clutch at all beyond coming to a stop.
