Northwest Members WA, OR, ID, MT, WY, SD, ND
New Clutch choice
Old 05-31-2006 | 07:36 PM
yekta's Avatar
Default New Clutch choice
as some of you may know, I burned my clutch the other day... This time I will be patient and wait for Ellis to do it However, I never liked the stiff feeling of spec stage 3 clutch. I want something can feel close to stock and hold up to 400-500whp easily, and at the track with very sticky tires.
Checking LS7 clutch out these days, seems reasonably cheap and good... What are your suggestions?
Thanks in advance
Old 05-31-2006 | 08:19 PM
B-RAD2's Avatar
i hear nothing but good things about the LS7
Old 06-01-2006 | 01:15 AM
99LSS1's Avatar
I think Eric (Ram-it) just had Ellis put one in his Z06 and he loves it.
Old 06-01-2006 | 02:18 AM
GEARHED's Avatar
Not quite sure as well but if its holding up with Eric's restless foot, it should hold up just fine.
Ya gotta ask the Groo Master himself - he rocks when it comes to what will hold and what won't
Old 06-01-2006 | 02:55 PM
bartman22's Avatar
Just out of curiosity, did you not like the stiffness of the pedal? Or was it the harshness of the on/off engagement style of the metallic puck friction disk? Just curious, because I see most people being happy with the easy pedal effort, but unhappy with the "lack of streetability." The SPEC stage 3+ is more streetable then the stage 3, as it does not chatter and is a bit easier to slip. I would also recemmend the LS7 clutch, as it is extremely streetable and well designed.
Old 06-01-2006 | 03:04 PM
LSxChevelle's Avatar
I say do the LS7...
Old 06-01-2006 | 05:42 PM
vetred's Avatar
Everyone says the LS7 clutch (AND flywheel) are way cool Im looking at them right now after LEARNING what NOT to do at the track
Old 06-01-2006 | 07:32 PM
yekta's Avatar
I guess it being stiff didn't bother me as much as the quick engagement point... This setup I had was horrible, I bought it used 1000miles... PP+clutch [stage3]+lightweight spec flywheel. First it was vibrating at high RPMs, then I got it balanced... It was better but still not perfect. Chattering and still vibrating a little, it is a nightmare...
After the harsh lap day, clutch couldn't hold that much power and energy and failed...
So far LS7 sounds like the best option, but I must be able to race the car
Quick Reply: New Clutch choice
