My forged 6.3" rods!
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
160mm center-to-center forged h-beam rods! 0.927" Chevy wrist pin so getting pistons will be easier
And ARP 7/16" rod bolts of course.
![](http://www.eric-o.com/images/volvo242/11-26-2006/DSC00027.JPG)
I'm getting serious
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I'm getting serious
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Yep it's for the Volvo. Hopefully will be pulling the engine and rebuilding it around springtime, I still need to get pistons and all the other little things. You would think that 4 would be cheaper than 8 wouldn't ya? These are custom straight from the manufacturer of Eagle rods, and ended up costing about the same as a set of 8 Eagle h-beam rods.
Originally Posted by Nate_Taufer
Ok. I was about to say you must hate having a decent amount of compression height in a piston but then I realized it's for the slow car.
Nate
Nate
That's the entire point. By going with forged 160mm rods, instead of stock forged 152mm rods, plus the added 6mm stroke, I get a piston that is 11mm shorter. Also, this gives me a Rod/Stroke ratio of 1.86. The piston compression height will be just over 28mm. By doing this, I will have dropped just over a pound from each cylinder. The bone stock head flows the same as a stock LS1 head. The head will be ported, and when I run 2bar boost, it will essentially be displacing 7.5L of uncompressed mixture. That in a car that has a dry weight of 2500lbs, will not be slow
Originally Posted by Poik
I'm not sure if you are just kicking me ****, or actually being a jackass ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
But yes, at the moment it is sitting on jackstands and goes 0mph, so you really got me there.
Haven't ordered pistons yet. They will be custom CP Pistons pistons. I know a guy who is doing similar pistons, so once he gets his I'll find out that information.
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
Mike
Tech Addict
Yeah I have been patiently awaiting Rick's response all day, where the hell is he?
Next thing ya know the volvo will have a bench seat mounted on the deck lid, dropped to the weeds with dub dubs on it, and stickers galore.
