Here Chebby Chebby
We are going to run it on ET Street drag Radials. Once we get it dailed in and hooking we are going to hit it with at least a 150 shot which should put it with or a head of mine
I am with you on the Cobra we all want to hear news like that
I need to go get some more files a The dyno and I will snag that file and take a look at it in SAE and Win Pep seven.BTW Winpep 7 shows my car at 607 RWHP and 561 RWTQ SAE Corrected and 633.88 RWHP and around 600 RWTQ UN-Corrected. There is one huge spike where it hit 845RWTQ where the tires let go on the rollers around 5,800.
UN-Corrected numbers look good but do not stand up season to season
Thanks for the words
I can sort of understand massaging the tq numbers to eliminate the converter's affect. But other spreadsheets I've used indicate I need 800hp to make my pig run the times it does. Actually, most say I need more hp. Please educate me Master Groo....
I might have to drop the n2o and go s/c the way things are going.bottle doesnt last for ever.
SVTOA Dyno Day.
The problem was not so much with the HP side of the numbers but the TQ side. Now every one likes big numbers but a 200RWTQ error seems to be enough for me to use the more acurate tool
Now as far as the numbers? TQ has as much if not more of an effect then HP at times and HP is in effect a calculation of TQ...IF calculated correctly
I personaly like tools to be as acurate as possible. would you use a TQ wrench that was off by 25%? I wouldn't
EJ. I think it is cool that the car laid down those numbers. Very impressive. But even GM never under reported numbers that far off. I am a little skeptical but hey arent we all. does not take away from his numbers a bit
It's been almost 15 years since I took those classes, so someone correct me if my memory is failing.
Which brings up another question. If I dyno my car on a Mustang Dyno, will I still have to roll into the throttle so it doesn't blow the tires away, or will I be able to nail it & get an accurate TQ reading? (since I figure WinPep 7 can't help that problem on a DynoJet)
The derivatives I remembered are from:
"Torque is the time-derivative of angular momentum, just as force is the time-derivative of linear momentum:
torque = dL/dt
where L is angular momentum and t is time."
Higher math is definitely a use it or lose it skill. I'm feeling old now.
Robert
DBAP.
SF's going on the COBRA on the 17th, thats a start..
Ken
I have had one for the last two weeks while here in Portland, do not like it.
It rattles like no other, my F-150 with 150K is more solid.
Cant reach the door to close it if you are sitting in the drivers seat.
Stupid ******* door locks stay way up even if the doors are locked, so when you go to rest your arm on the window seal you have this thing poking you in the arm.... BS I say... go GM
Oh, It handles like I have two flat tires in the *** end, wiggles everywhere...
bottom line, me not like
Ken
