Help with 99 Suburban running issue
Hooked up my scanner to it and watched it and seems like when it was dieing the Narrowband O2's had a long delay before any information really changed, up to 4 seconds sitting at 80. Went through this cycle about three times and than it died looking back at the scan. MAF was getting a signal and the truck isn't throwing any codes. Fuel pump is new and can turn it on with HPT and can hear it pump up and the schraeder valve spews out gas, doesn't drizzle out so pretty sure it isn't a problem with the fuel getting to the engine. There is also spark so that eliminates any speculation on any sort of crank sensor or anything ignition related being bad. Only thing I can think of is that something for the injectors is overheating. I was wondering if the O2 sensors could be bad but I would think if they were bad the truck would just run like crap and not just die.
Anyone have any suggestions of other places to look. I am pretty sure it is something Injector related but not sure what it could be. Like I said, fuel is getting to the manifold but for whatever reason it isn't getting to the cylinders. Pretty sure they are not plugged, if they were I would expect it not to fire back up after it sits for a couple hours. Anyone else experienced something like this?
Think both of them being bad could cause it? Was thinking it was Bank 1 because it was the one that seemed to have the longer delays in the scans.
Also the other main igition problem with the Vortec engines of that vintage is the distributor cap, they will burn through inside from the center electrode and short between the different cylinder contacts. This is a very common problem with these, also inspect the coil wire. When you replace the cap, don't go CHEAP here get the best cap you can such as a OE AC Delco piece, Blue Streak, NAPA Gold Series, most parts house carry a el-cheapo line of ignition parts, don't go there.
Wire from coil to distributor was bad! It would get so hot that it started melting.
