painting my rims
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
Ok so the clear coat on my stock rims are peeling and it looks like crap so im am going to paint them gun metal gray with duplicolor wheel spray. I was just wonder if i have to primer the wheels and would the wheels be fine without clear coat???? i think i am going to clear them but its such a pain in the ***...clear coat is so touchy.
"1. Always read specific can instructions to achieve maximum results.
2. A clean, dry surface is important. Follow these preparation tips for best results:
• Remove dirt, wax, grease, moisture, rust and loose paint.
• Sand or scrape, if necessary, (sandpaper, steel wool, wire brush, scraper).
• Sand rusted, glossy or hard surfaces to improve adhesion.
3. Paint in good weather only.
• 55° to 75° F is ideal; 40 to 60% relative humidity is recommended
• Avoid direct sunlight and hot, humid weather.
4. Observe the proper re-coat opportunities. See product directions for suggestions on when to apply a second coat.
• Example: Dupli-Color® lacquers can be re-coated anytime. Dupli-Color® enamels re-coat within 1 hour or wait till after 5 days.
5. Test a small surface area for paint compatibility.
6. A smooth, even application is important. Follow these tips for success:
• Use an even, side-to-side motion with each pass beginning and ending beyond the edge of the object.
• Use a fan spray vs. regular spray distance to the object.
7. Take your time.
• Use 3 light coats vs. one thick coat.
• Always check recommended recoat time.
8. Avoid over spraying.
• Mask exposed areas with drop cloths.
• Clean up with appropriate cleaner-paint thinner or soap and water.
9. Ensure adequate ventilation."
"Wheel Paint
This advanced polyurethane formula creates a tough, durable coating to protect steel and chrome surfaces from oxidation and severe weather conditions. Available in popular finishes. Ideal for hubcaps, trim and accessories. "
Doesn't look like you need to use a clear over the wheel paint considering it has polyurethane in the color.
Copied it from duplicolor's website.
http://www.duplicolor.com/solutions/tips.html
7. Take your time.
"Wheel Paint
Ive done the duplicolor gunmetal before...I would advise tossing a clear on them when you are done. Looks 100% better. I used a primer with mine, but you dont have to from what some of my friends told me.
i used just 2 coats of clear , didnt primer just used sealer
[IMG]http://i106.photobucket.com/albums/m280/gilbertandnatyforevera
a lil dusty
/ggggggggggggggggggggggg023.jpg[/IMG]
a lil dusty
![](http://i106.photobucket.com/albums/m280/gilbertandnatyforever/ggggggggggggggggggggggg022.jpg)
