welding/ sheetmetal question
Old Mar 28, 2010 | 02:29 PM
tektrans's Avatar
Default welding/ sheetmetal question
I had to cut out some of my floorpan and replace it with 22 guage sheetmetal.
I spot welded it all around, there's maybe 3/4"-1" between each weld.
What do I use to fill in the gaps? No way I'm spot welding that thing till it's all sealed, I'm not the best welder to begin with.
Any help appreciated.
-Mark
Old Mar 28, 2010 | 02:39 PM
bigj2717's Avatar
Seam sealer or rtv can help keep water out
Old Mar 28, 2010 | 03:50 PM
tektrans's Avatar
where do I get that stuff? Auto parts store?
Old Mar 28, 2010 | 04:49 PM
bigj2717's Avatar
Yeah some auto parts stores have it or paint shops
Old Mar 28, 2010 | 05:49 PM
tektrans's Avatar
Cool thanks. Does that stuff dry hard? can you paint over it?
Old Mar 28, 2010 | 05:50 PM
tektrans's Avatar
how do you apply it?
Old Mar 29, 2010 | 12:08 AM
black_sheep454's Avatar
For you a brushable seamsealer would be best, just lay some tape around the seam on both sides and follow instructions. It's pretty easy to use, and can be painted when dry. Practice with some on some scrap until you get it to layout like you want it to, and after you spread it you can take some water on finger to smooth it out some if it's to rough
Old Mar 29, 2010 | 11:29 PM
toplessHO's Avatar
they make weld thru seam sealer
you apply before you put the panel down and spot weld it.
Old Mar 30, 2010 | 09:36 AM
Whistler's Avatar
Sawzall and Welder Mod
Ive used weld through primer, but never seen weld through seam sealer.. have you used it before?
BTW you should try and add a few more welds if you have them .75-1" apart. Try and get them about half that and it will flex/fatigue much less.
For seam sealers, your auto body supply store will have at least 20 different kinds depending on what you want it to do. There's brush on kind (easiest and cheapest) kind that is applied with a caulking gun, 2 part kind that is applied with a dual-tube automix gun, thick, thin, self leveling, etc. The 2 part kind will actually harden (still flexible) and is the best kind for a permanent seam and is most like the factory. I like the 3M 8236 best.
If youre on a budget get the brush on kind. Just make sure you clean your welds good with a scotchbrite pad first, spray a little primer down, then put the seam sealer on top of the primer once its dry. Then you can paint over top of the seam sealer once it sets.
Old Mar 30, 2010 | 12:55 PM
Also never heard of weld through seam sealer, only primer
Old Mar 30, 2010 | 10:21 PM
Marc3.4V6's Avatar
22 gauge is pretty thin, your floor pan is going to be around 18-16 gauge. There is no such thing as a weld through seam sealer, it makes no sense and would have no purpose as you would have to seam seal over anything welded anyhow.
Old Apr 4, 2010 | 10:53 AM
toplessHO's Avatar
Wrong description but heres what should have been used
3M 8115 Panel Bonding Adhesive .
Can be spot welded when wet.
I have heard of others that can be squeeze welded while drying,I think Lord makes it. They have little glass BBs that will fracture when compressed.
Old Apr 4, 2010 | 11:28 AM
01ssreda4's Avatar
Seam sealer is good ****. That being said if there are adequate welds for strength, and you are just trying to make the repair air tight. Get some Ultra Black Rtv in a tube from the auto parts store. And smear it on. It will dry firm but not hard. I recently used this on a section of floor plan and it has done fine.
