removing double sided taped residue.
completely de-badged my car and took off the rubber door ding strips and not all of the adhesive came off, just wondering what the best way to get all that off without harming the paint. thanks.
I just de-badged my AVy this weekend and had the same issues. I used REM OIL (its basically like wd40 but i didnt have wd40 on hand) to take all the foamy parts off, just spray it and use a credit card or something similar to gently scrap it away. this should leave just the sticky residue which is a pain in the *** as well. for this i used a all purpose lacquer thinner and gently rubbed the area until it started to come off, rinse and repeat several times because you dont want the thinner to set on the paint to long.
The most simple and the least harmful way is to use a roll off wheel, its a soft rubber wheel that "rolls off" the glue and foam backing. It takes about fifteen minutes to do both sides and won't harm the paint at all. You can get them from Norton abrasives, part number 63642505624
Do not use laquer thinner or goof off. Both of these will take paint off. Use the wheel or 3m makes an adhesive remover. Also just imho find out ppls skill level and training before taking advise. Some of these guys ideas will screw your paint for good.
Tewlver12 had it right. Just use the rub off wheel. Dont soak it in anything. Its designed to be used by itself.
Ok, take my skill level into account. I have been restoring cars for 7 years now, and I know how to take adhesive off. Take a look at my car and you can see my work. I don't have to prove myself to some tool with 19 posts. Anyways OP, I can say the adhesive remover is just as dangerous as thinner. Sorry buddy, but goo gone will not take off paint. That is very incorrect info. Matter of fact, I just did my truck like a month ago, and it sure doesn't look like my paint is gone! The advantage to soaking the tape in goo gone is to reduce the amount of **** to clean up after the fact. It keeps it balled up into one area so that you can simply wipe it off.
