paint the windshield cowl trim ?
Old Apr 18, 2011 | 01:57 PM
datenbrick's Avatar
Default paint the windshield cowl trim ?
Has anyone ever painted the windshield cowl trim? What paint did you use?
Old Apr 18, 2011 | 07:04 PM
SinisterZ28's Avatar
Satin black trim paint in a spay can, I use worth, but you may get it at the local paint store,if not ask them what they would recomend
Old Apr 18, 2011 | 07:09 PM
I would lightly scuff with a grey scotch brite,wipe with wax n grease remover,wipe with a tach cloth or at least blow off then paint,3-4 light coats then maybe 1-2 med coats(not necessary)
Old Apr 18, 2011 | 07:16 PM
fucter's Avatar
I used meguiers back-to-black, its not quite paint, but worked well for me
Old Apr 18, 2011 | 07:36 PM
99ls1vert's Avatar
I painted mine with gloss black, and painted the wipers and arms with SEM trim black. It looks great and its been over a year.
Old Apr 18, 2011 | 08:00 PM
HAte's Avatar
WURTH satin black trim paint is AWESOME, it drives soooo even and goes on so smooth, perfect for trim pieces like that and wiper arms etc
Old Apr 18, 2011 | 09:50 PM
Swiat34's Avatar
I've seen where someone sprayed several coats of filler primer, sanded it smooth, covered with sealer primer then used body-color paint and clear. Looked REALLY nice!
Old Apr 19, 2011 | 01:57 AM
datenbrick's Avatar
thank you ^^^^^^^^
Old Apr 19, 2011 | 02:04 AM
808z28camaro's Avatar
Adams Polishes VRT works awsome to make it look new
Old Apr 19, 2011 | 02:12 AM
floodofnoise's Avatar
I used bondo restore black, it is like a gel with a really black pigment in it. Looks awesome imo.
Old Apr 19, 2011 | 10:31 AM
Swiat34's Avatar
Originally Posted by datenbrick
thank you ^^^^^^^^
No problem! Check this out! https://ls1tech.com/forums/appearanc...iper-cowl.html
Old Apr 19, 2011 | 01:14 PM
SRZ's Avatar
SRZ
Couple of coats of primer, and high temp black w/ about 8 coats. That was 10 yrs ago and haven't painted it since but I do keep the car in the garage but still.
Old Apr 19, 2011 | 01:32 PM
firemech21's Avatar
I just painted mine last weekend. i removed everything, scrubbed it clean with some rubbing alcohol and painted the cowel, wiper arms, and covers with a satin black and it looks amazing. Now i just have to find out how it holds up to the TX sun, but a friend did his about a year ago and it still looks good.
Old Apr 20, 2011 | 10:14 AM
dubga's Avatar
I used Krylon Fusion satin black on mine last summer. Still looks good.
Old Apr 20, 2011 | 12:38 PM
chon79's Avatar
I painted mine with Krylon Fusion and it faded pretty bad.
I am going to try a good prep and re-paint now that its warmer and see how it holds up.
Old Apr 20, 2011 | 12:44 PM
APG12's Avatar
How do you remove the cowl on a TA? The wiper arms have to come off right? I heard that can be a b*tch.
Old Apr 20, 2011 | 12:49 PM
chon79's Avatar
Yeah it can. Just pop off the wiper arm covers, remove nut. I use a flathead screwdriver to help pry off the wiper - its pressed on. Just be careful not to hit and crack your windshield.
There is a wiper arm remover tool you can buy from your local auto parts store, but I hear that it does not work too well for our cars.
Old Apr 20, 2011 | 02:27 PM
Swiat34's Avatar
Wrong on the screwdriver! You'll only cause damage. Take the nut off and use a regular claw hammer to lightly tap the bolt while lifting up on the wiper arm. No hard smacks.
Old Apr 20, 2011 | 03:37 PM
VinR1's Avatar
OR... take the nut off, lift the arm, get a good grip and yank like you're jerking it off... one or two good jerks is all it takes
Old Apr 20, 2011 | 03:54 PM
dubga's Avatar
I agree with the man with the awesome avatar. Wiggle the arm a little between hammer hits. I found out that mine was already loose but wasn't sliding off because I was pulling on the arm at a bit of an angle. I was still smacking away with the hammer, finally I stopped and wiggled the arm and it slid right off.
