Is there a difference between the Trans Am High Rise wings....
No, there is no difference, they are interchangeable.. theonly difference may be the 3rd brake light harness where it unplugs at the top of the hatch... there was a single rib on one of the hatches I swapped out but justshave it off with a razor... if youre putting an old 93 hatch on a 2000 then you may have to do that but its a no brainer.. some of the cars made in Canada had slightly different plugs on some of the harnesses but not all of them... so to answer you question more clearly.. They are all interchangeable...
There are actually
1 birdbath, on v6, formy, and verts...
2 highrise, on TA and Hawk or any other V8 typically
3 Firehawk 1, low rise like bird bath but has two little like this..
![](http://memimage.cardomain.net/member_images/7/web/823000-823999/823245_24_full.jpg)
4 Firehawk style 2,
![](http://image.highperformancepontiac.com/f/9861250+w750+st0/hppp_0708_03z+2002_pontiac_firehawk+.jpg)
The last two are very rare to find anymore..
There are also a couple more but they are for Mechams and Sevan series but I wouldnt consider them factory
![](https://t1.gstatic.com/images?q=tbn:ANd9GcQARDDrYuQaDi-y3Dl-VkBHXG70pcbw3EKX-sUFL3vn1BCaXDTLPm1S3_9a)
All of these will bolt up to your car, with the only difference possibly being the harness up top behind your dome light... nothing else...
4 Firehawk style 2,
there are two firehawk wings..
Check with InfiniteReality, he owned that car. He will be able to tell you about it and post up pics im sure.
here is another one I found with google search images
![](http://memimage.cardomain.com/ride_images/3/2858/661/32142830002_large.jpg)
