Bad Idea? Sandblasting underbody
My car is pretty much bare from the dash back. No trans, driveshaft, rear end, gas tank, brake lines, etc. I have removed EVERYTHING. It's about 3 feet in the air and I have been going at it with wire wheels but progress is so slow I am looking for an alternative. There is rust that needs to be addressed and I know blasting will quickly get me where I need to be to start repairs and paint.
If anyone has experience with this and is willing to offer advice I would greatly appreciate it.
In my opinion, the time you save with the blasting will be made up once you try and get all the sand out. It might end up taking longer or just as long with the wire wheel. Sand is very messy.
Now you can try and cover as many holes as you can before blasting. Just try to avoid hitting the holes directly. And have a strong vacumm handy.
Did you use sand or another media? Are any easier to clean up?
Just do this...
Cover up as man holes as you can with a few layers of duct tape. Remove any moving parts such as suspension and bushings. Then blast the hell out of it. Be sure to use a good respiratory mask, safety glasses, gloves and a thick jacket. When that stuff hits your skin it stings. Also, create some kind of barrier around the car to prevent the sand from getting all over the place. <<<--- trust me, you want to do this.
Now to clean up, get a good strong shop vac and a air piston with a narrow tip so that you can get into the hard to reach places. When cleaning up use the compressed air and the shop vac at the same time. The compressed air will move the sand around and the vac will capture it. Good luck.
Can anyone recommend a soda blasting place in Michigan? Do you think they would do it to a roller (ie not on a rotisserie) ?
