I just started painting my car ...PROBLEM SOLVED!!
#61
^this is exactly why i dont miss solvent bourne paint.anyone that paints water bourne paint is with me on that. i always harden my base coat when i paint whole cars makes life so much easyer when you do it for a living. glad you got it figured out man.
#63
UPDATE
Ok guys I finally got all the paint from the rocker panels, door jambs and engine bay stripped off over the wknd. I washed everything down with a 3M scuffing pad and some soap/water. After that I applied one coat of adhessive promotor in aerosol form.
TIPS:
For those who are looking for a good paint stripper I highly recommend this paint stripper... http://www.wmbarr.com/product.aspx?catid=72&prodid=112 At 1/2 the price of Aircraft stripper it works just as good or better. Home Depot has it for under $7/per can.
As for the new paint that the paint store reimbursed me with... I sprayed a metal fender I had laying around and it came out perfect. I didn't spend a lot of time prepping the fender as I just wanted to see if the paint was going to wrinkle up again. I scuffed it with 320 grit, cleaned it and applied sealer/base/clear. Base was reduced 1:1 and no hardener was added. So I guess it's good to go this time.
Now I just have a few questions...
Should I just spray a coat of sealer and start applying base/clear OR should I lay down some primer first?
Does the adhessive promotor need to be scuffed before I apply the sealer or can I apply the sealer directly over it as is?
TIPS:
#64
![Unhappy](https://ls1tech.com/forums/images/icons/icon9.gif)
There are Chinese products everywhere these days and it could be that your paint store is substituting. eBay is full of Chinese fiberglass products and I would definitely pass on the Chinese abrasives at Harbor.
#66
Man I haven't worked on it for a month now. With all the family events and holidays, I just haven't had time. The doors, jambs, rocker panels and engine bay are done. The driver side 1/4 panel has a staine on it right where it meets the roof so I'm doing to just sand down the clear, shoot 1 or 2 coats of base again and reclear it.
I'm off work all next week so I'm going to put all my time and effort into it. I'm trying to buy a house next year so this car must be done first.
#68
Here's a few pics of the doors...
![](http://i357.photobucket.com/albums/oo13/sparo2/Mobile%20Uploads/IMG_2376.jpg)
![](http://i357.photobucket.com/albums/oo13/sparo2/Mobile%20Uploads/IMG_9565.jpg)
I'm definitely putting some work in this wknd. One way or another that car is getting painted painted this month...even if I have to sleep in the garage. lol.
My only concern right now is the weather. It's cooler know. Before I was working with temps in the mid to high 70s. Now I'm working with 60-65 degree weather. It's a bit warmer in the garage when I have it closed though. Any comments?
#69
This has gotten far too complicated.
I use dupont chromabase sealer/base. I use SPI universal clear (******* awesome stuff seriously)
Everything is mixed 1:1 except for the sealer.
In my SPI tech sheet it states to allow the base to dry as long as possible to avoid future complications. Also cheap base will ruin a paintjob also, it will fade/discolor/etc. Its not just about having quality clear, you want quality clear and base. They work together.
#70
Ok guys, the weather has finally started to cooperate. I'll be painting this rest of the car this wknd.
The fenders and hood are pretty much good to go. I just have to fit them with the 400/600/800 grit. Here are a few pics of the bumper ready for sealer/base/clear.
![](http://i357.photobucket.com/albums/oo13/sparo2/Mobile%20Uploads/IMG_5287.jpg)
![](http://i357.photobucket.com/albums/oo13/sparo2/Mobile%20Uploads/IMG_1306.jpg)
![](http://i357.photobucket.com/albums/oo13/sparo2/Mobile%20Uploads/IMG_9204.jpg)
Hopefully all goes well this time. If so, I should have the car completely done by next weekn and I can continue working on my twin turbo setup.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#71
UPDATE
Ok guys I finally got a chance this wknd to paint the trunk, hood, fenders and front bumper. All I have left to paint are the mirrors, rear bumper and spoiler. The roof and rear "CAMARO" panel will be painted black. I figured if I can paint the rear bumper, spoiler and mirrors by Wednesday and then the roof and rear panel on Thursday/Friday I'll be completely done painting the car.
In the mean time, here's some updated pics...
![](http://i357.photobucket.com/albums/oo13/sparo2/Mobile%20Uploads/IMG_2742.jpg)
![](http://i357.photobucket.com/albums/oo13/sparo2/Mobile%20Uploads/IMG_4444.jpg)
![](http://i357.photobucket.com/albums/oo13/sparo2/Mobile%20Uploads/IMG_2543.jpg)
