single vs tri-stage paint???
thanks,
nick
And instead of painting where the scratches/chips are. Repaint the whole panel vs trying to blend with it.
the car was in an a fender bender so the whole front end also has to be shaped/painted. i want to tackel this myself to save on labor charges, also student budget. i can imagine a hell lot of bondo to shape the front end and those cans combined with primer can be expensive. so i want to try and save money... would the single stage work out for the fenders, hood and front end since i am basicly doing the whole job of shaping to painting? what about the doors and quarters, could it blend in easily?
what do u mean by you will be able to see "the spray of the paint"? I prep for both types of paints jobs everyday and i guarentee you the prep is different. Although similar prepping for bc/cc has more steps.
I personally would go with the base coat clear coat set-up vs single-stage, considering you can tell the difference when the single 'dies' down after a period of time especially for a daily driver that is sun-beaten everyday.
Do not attempt to blend panel ( if you are talking about blending within the same panel ? ) as the cost difference does not justify a foggy or rough edge of the clear as you will not end liking the end product, thus spending more money in the end to fix
that's one way, the other way some blend the clear into existing clear, really doesn't apply to f-body as much as it would a truck or suburban 1/4 panel.
