Guestimate on painting a door and blending it? (SOM)
Someone hit the door on my TA a while back and on the inside it is cracking the fiberglass and the shops I have taken it to say they would have to cut away and patch the door and do a lot of work. I think it would be easier to find a good condition door and have it painted and matched so the sagging that is already happening isn't an issue.
Anyone have any experience with what it might cost to get the door painted and have it blended? I would attempt it myself but don't think I have the skill to make something like that color blend with the colors around it, and the bottom trim of the car would need repainting from the door sagging.
Any suggestions? I found a perfect door at one of the local wrecking yards that from my look over it, seems like it is in mint condition, so thats half the battle won already!
Originally Posted by stevethepirate
SOM is also more expensive than most other colors..
Somewhat more expensive, but not too much. The real cost comes in the labor for blending into the adjacent panels which in this case are the front fender and rear quarter panels. That should definitely be done in the case of a metallic color.
Bryan
Bryan
Bryan
If you have any kind of skills buy the door, have a quart of DBC mixed up, jamb the door and hang it yourself, pull the weatherstrip off and take it to the bodyshop and let them squirt the side of the car.
I have a 00' Red WS6.
I had to have my door replaced, and blended.
Door - $890
Paint and Labor - $800
Take note that my car is a flat red color...and yours is a rare metallic color. Which means youll be spending more money than I did...but probably by only $300 extra
Door - $890
at most body shops that do high quantities of work they have mixing systems which means they mix their own paint all colors are the same unless its a tri coat then it higher but a shop that buys their paint mixed it will be higher then no metalics
yeah my shop just has the computer that gives all the mix ratios and we mix everything right on the spot. then spray the color on a test card, then if it needs tinting we tint it to match perfectly. heres the thing since your painting an entire door plan on blending both your fender and the quarter panel so that you have a good blend. now your color isnt 3 stage so it shouldnt make much of a difference from standard colors in shops that make there own mixtures. on that junk door make sure you check everything and every angle in the light because you mite find dents and stuff which will cost extra labor in the long run. id say to do the door fender and quarter without body work on the door it should run like 800-1200 depending on the shops rates.
