Primer and Paint Question
Will it stay, or do I need a higher grade automotive primer for the paint to adhere correctly?
Thanks in advance for any help.
i'm not a professional, but i took two years of autobody school, so i'd like to think i know a fair amount of what i'm talking about. but maybe a pro will chime in, too
a) either they're going to be fine with it and just paint the parts... or
b) they will sand off whatever primer you put on and spray on a higher quality primer
just call them and ask them. that would be the easiest way to go, that way you can save some money on not buying primer if they're just going to sand it off.
if you spray it yourself just make sure you've got the right grit paper so that the primer has something to "bite" into. that will help with the adhesion.
180 grit do not get to hot u will bring mold release agents to surface if using a da go slow
then clean with soap and a scotchbrite
clean again with water and scothbrite
clean again with acohol based grease remover i use 91% alcohol
adhesion promoter
flexible primer surfacer
wet sand with 400
clean with soap and water
clean again with alcohol based cleaner
flexible sealer
then base (i use ppg it doesnt need flex in the base)
then clear with flex additive
no rattle cans unless u need a guide coat to wetsand by lol
im not tryin to be an *** im just speaking from experience painting plastic right the first time saves lots of time and money
adhesion promoter
wet sand with 400
flexible sealer
i'm just trying to understand what you're reasoning is behind it.
because with plastic the main thing is cleanliness because any left over soap residue will cause adhesion problems
when painting u should spend more time cleaning the part and booth then spraying it
yea u must add flex additive unlest u like to see your pretty peice of art turn into **** months down the road
without it--it will look good and flex some but thats because it hasnt truley 100% cured so when it does finally cure completely then u will have some cracking
my instructor told me that the only good the flex additive is for is for when you are mounting things, or you know, before it has really cured. after it has cured it doesn't do anything. any truth to that??? it seems like once everything has cured a flex additive wouldn't help, at least in my thinking, but i could be wrong.
