WS6 badge removal help!
Old Feb 28, 2008 | 09:21 AM
alihamza's Avatar
Default WS6 badge removal help!
I'm debadging my WS6. I tried to use dental floss, but it wasnt nearly strong enough. The adheasive it tough! Maybe a heat gun, and some fishing line? Thanks for any responces!
Old Feb 28, 2008 | 09:26 AM
Arc00TA's Avatar
I just grabbed it with some needlenose on the corner and tugged and it came right up. Maybe my adhesive was crappy though.
Old Feb 28, 2008 | 09:40 AM
torquejunky's Avatar
I wouldn't recommend using a heat gun, just use some fishing line and some adhesive remover after you get it off of there. You might want to wrap the fishing line around something to hold if it's being real stubborn.
Old Feb 28, 2008 | 10:06 AM
5301113's Avatar
+1. Do a sawing motion pulling the fishing line towards you so you won’t scratch up the car. Once the badge is off put a lot of adhesive remover ,let it seat and then use you fingers to remove the glue/ tape. P.S. take your time
Old Feb 28, 2008 | 12:04 PM
alihamza's Avatar
Thank for the quick responces everyone! I am going to try the fishing line method. I'll let you guys know how it goes. Thanks again!
Old Feb 28, 2008 | 12:35 PM
phantazn's Avatar
a credit card also works. like everyone says, just go slow and take your time.
Old Feb 28, 2008 | 05:21 PM
Chadz89GTA's Avatar
+1 on the fishing line, make sure you get some strong line so it won't break and wear gloves or you'll cut your hands up like I did, Lol.
Old Feb 28, 2008 | 08:42 PM
2001somws.6's Avatar
wd40 works wonders also.
Old Feb 29, 2008 | 10:48 AM
5301113's Avatar
ouch. i wrap the fishing line around two pens i had more control like that even with gloves i couldnt hold it that long.
Old Feb 29, 2008 | 02:03 PM
-98-Z28-Darkness-'s Avatar
hear fo people usinf fishing line and levign the car in the sun for a wile.
Old Mar 1, 2008 | 04:17 AM
samanthablack87's Avatar
heat gun and fishing line together always work for me
Old Mar 2, 2008 | 12:56 PM
stealth1281's Avatar
why would you want to de-badge your ws6 anyway?
Old Mar 2, 2008 | 06:59 PM
White 96LT1's Avatar
man leave that badge there? defines exactly what the car is and be proud of it
Old Mar 4, 2008 | 10:34 PM
yodas little brother's Avatar
buy an eraser stick it on a drill or die grinder low rpms takes any glue or pinstripe right off
Old Mar 4, 2008 | 11:10 PM
SweeTbone's Avatar
I used a hair dryer and dental floss to get my door emblems off when I changed them silver. Sounds corny, but it worked perfect.
Old Mar 5, 2008 | 12:09 AM
AiDRocks's Avatar
I removed mine on a hot day. I let some tar removal stuff soak into the backing then followed up with fishing line. I heard waxed dental floss isn't too bad either.
Old Mar 13, 2008 | 04:11 PM
67pontiac's Avatar
heat gun an it will pop right off i took mine off real easy thar way or a hot hair dryer
Old Mar 13, 2008 | 06:03 PM
yeller_xtc's Avatar
eraser wheel will eat you bumper, use a clean bondo spreader. or a piece of nylon strap that holds boxes together. any body shop will have some in the trash. much better than fishing string. or dentail floss lol
Old Mar 13, 2008 | 06:17 PM
mikey67's Avatar
+1 This worked very well for me on my Grand Prix, although a couple of them pulled off quite easily. Hair dryer isn't as harsh as a heat gun and waxed floss left no marks whatsoever. I then soaked any of the remaining adhesive with some aerosol bug and tar remover and was able to "roll" the rest of the adh. off with my thumb.
Old Mar 19, 2008 | 08:15 PM
bulldogSS's Avatar
the only thing ive ever used to get emblems of is a 4in wide paint scraper. if your very very carful itll cut right through the double sided tape without scratching the paint. if your scared to try it ive seen a few guys at the shop use welding wire.
