View Poll Results: Engine color and rear color
Engine Chevy Orange, Rear Black
2
20.00%
Engine Black, Rear Black
7
70.00%
Engine and Rear Chevy Orange
0
0%
Other colors, add your own thoughts
1
10.00%
Voters: 10. You may not vote on this poll
Por-15
1 Post
Por-15
Anybody use it on their engine, rear or any part of their car? What kind of results did you get?
Was it easy to apply?
Did it flake right away?
I am about to buy some black to paint (POR-15) my moser rear that is about to go into the car.
I am also getting some chevy orange to paint (POR-15) my new iron block. The car is white but I want to paint the iron block to slow the rust process.
Any comments welcome, opinions about colors for the block or the motor. This painting will start when I get home from deployment pretty soon.
Thanks for reading, and please post pics of examples if you got 'em.
Jon
Jon
A guy I know from another site, did the whole underside of the unibody with por, I also did my floor pans with it after I put the new ones in.
Sorry I have no experience with using it on engine parts, but here are some pics:
por 15 is awsome! just dont put it on any bolts you might want to get off ever because when it drys its harder than steel! i used it on the frame of a 80's silverado of mine that was rotting out and it totally stoped it and looked good but if it is exposed to direct sunlight it dulls fast. but its good stuff.
I coated my entire passenger floor board to cure some rust and also used in on the rear end. I highly recommend this stuff. I haven't noticed any flaking or adhesion problems.
It doesn't stick well to smooth surfaces, it will come off with the scrape of a fingernail on them (bare smooth steel for example). The surface needs some roughness to it for it to 'bite'. Also, don't paint over it for at least a week after application, or it will bubble up on you (happened to me).
It does smooth out nicely, even when brush applied.
I don't like that it's air activated, and if you don't use up what you have fairly quickly, the whole can goes bad. I like 2-part stuff (like epoxy primers). Of the POR-15 I've purchased, about 40% of it ($$) got thrown away. Of the epoxy primer I've purchased, virtually none of it was wasted.
I used some to seal the trunk floor of a 71 mustang that had several pin hole sized rust holes. I hadnt removed the gas tank at that point, And almost never did. i tore the tank all to pieces trying to get it loose where 4 or 5 places had glued it to the trunk floor. I believe it was originaly created to coat oil rigs where metal is constantly attacked by salt. 5 years ago i got some on a pair of pants i had, thats the only part of the pants left..... lol. TUFF STUFF!!!! wear gloves
I hate to say it but the stuff sucks.
It LOOKS good, but did it stop rust? Who knows it's black.
When I bought POR 15 they said clear is the same formula as black or any other color, you just can't use it in the sun.
Ok, so I took a steel framing square, prepped as the instructions say, didn't remove 100% of the rust because POR 15 claims to stop rust.
After a full cure I put the framing square out in the grass in the shade. After about 6-8 months you could see the rust spider webbing. after a year and a half the surface was no longer smooth and there was a ton of rust.
Now, get black, put it on your floor board and put carpet over it, it's going to be a long time before you realize it never stopped rust.
I've had better luck with rustoleum rusty metal primer.
