Typhoon Direct port nitrous setup, injectors, balancer, thermostat valve covers more!
Category: Audio/Video/Electronics
Price: $1450
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird
Location (State): MA
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
Everything pictured with the nitrous setup is included with the price besides the aeromotive fuel pressure regulator. But you also get a 4an nitrous feed line that is not pictured. It is still in my RX7 but will be included with the sale.
Whats included: -$1450 (over $2,200 invested in this setup)
Professional Products Polished Typhoon Intake
PP polished 85mm throttle body
PP fuel rails
Direct Port Nitrous setup up to 500hp shot
Stock Ls1 injectors
2 NOS Fuel solenoids Fuel cheater #16050 each good for 250hp ($180 each new)
2 NOS Nitrous solenoids Super Pro Shot #16045 each good for 250hp
8 NOS Foggers
All fuel a/n complete and setup to run nitrous setup off of the vehicles fuel system
Nitrous Express bottle
NOS purge solenoid
4an Nitrous Feed line
Intake manifold to cyl. head gaskets
2 toggle switches
2 momentary switches
2 automotive relays
Bosch "White Giant 36lb Injectors - $165
Used but in great shape w/all new o-rings, baskets, cleaned and flowmatched. They flow 41lbs @LS1 fuel pressure of 58psi. They will support up to 500rwhp.
LS2 160degree SLP T Stat NEW - $15
Never got around to putting it in my CTS-V but its new and ready to go.
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10645.jpg)
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10647.jpg)
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10642.jpg)
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10641.jpg)
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10640.jpg)
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10639.jpg)
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10637.jpg)
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10636.jpg)
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10635.jpg)
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10634.jpg)
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10633.jpg)
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10632.jpg)
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10631.jpg)
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10630.jpg)
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10649.jpg)
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10650.jpg)
Thermal fan switch Kit - $20 NEW
Thermal Switch Style Non-adjustable fan control kit
Sending Unit Style Thread-in
Sending Unit Included Yes
Sending Unit Thread Size 3/8-18 NPT
Fan Quantity Single/Dual
Fan On Temperature (F) 180 degrees F
Fan Off Temperature (F) 170 degrees F
Relay Included Yes
Wiring Harness Included Yes
Manual Override Switch Included No
Air Conditioning Relay Included No
Quantity Sold as a kit.
Derale Cooling Products single-stage fan controllers can be installed in the radiator or a threaded location. They activate fans at a specific temperature and turn them off at a preset temperature. The controllers are available for single or dual fans, and specific types will work on vehicles equipped with air conditioning.
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10472.jpg)
8an inline 40 micron cleanable fuel filter - $20 NEW
Summit Racing Part Number SUM-230105
Fuel Filter Style Inline
Inlet Quantity One
Inlet Size -8 AN
Inlet Attachment Male threads
Outlet Quantity One
Outlet Size -8 AN
Outlet Attachment Male threads
Filter Element Included Yes
Smallest Particle Filtered 40 microns
Filter Element Material Stainless steel mesh
Filter Housing Material Aluminum
Filter Housing Finish Blue anodized
Overall Length (in) 4.000 in.
Outside Diameter (in) 1.250 in.
Mounting Bracket Included No
Fittings Included No
Clamps Included No
Maximum Fuel Pressure (psi) 75
Quantity Sold individually.
Notes Can be used with gasoline only.
Designed for carbureted systems, our filters flow 130 gph and have a reusable 40-micron element. Each 4.00 in. long filter is machined from aircraft-quality billet aluminum. They're available in red, blue, or black anodized or polished finishes with -6 AN or -8 AN fittings.
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10431.jpg)
NOS Solenoids w/fittings - $100
N20 Cheater solenoid #16000
Fuel Cheater #16050
Both in good working order.
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10601.jpg)
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10600.jpg)
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10599.jpg)
2 New Pirelli P7000 245/45/16 $65 each
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10616.jpg)
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10619.jpg)
Center bolt LS1 Valve covers power coated black - $125
Bolts and gaskets included, valve covers are in good shape but the powder coating isnt the best. As seen in the pictures there are some imperfections in the coating. But I have adjusted the price accordingly.
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10611.jpg)
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10612.jpg)
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10613.jpg)
NOS Nitrous solenoid - $40
Great used solenoid for small nitrous shot or purge valve.
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10598.jpg)
Nitrous Express gauge with bottle adapter to 4an NEW - $45
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10592.jpg)
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10595.jpg)
Nitrous Express blow down tube and blow out fitting NEW - $25
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10589.jpg)
Relay Included Yes
Inlet Quantity One
Inlet Size -8 AN
Outlet Quantity One
Outlet Size -8 AN
Clamps Included No
Fuel Cheater #16050
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10591.jpg)
PowerForce keyed Ls1 engine damper NEW - $65
This is an affordable damper for the popular LS-1 G.M. engine. This model fits 1998-'04 Camaro and Firebirds with the LS-1 engine. Although not required for stock engines, this damper is equipped with a keyway and timing marks. This damper is dimensionally identical to the stock damper but is made of tough nodular iron and features bonded elastomer construction.
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10585.jpg)
Autometer Ultra Lite 2 1/16" Air Fuel Ratio gauge - $30
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10588.jpg)
Autometer Ultra Lite 2 1/16" mechanical Fuel Pressure gauge - $30
All I have is what is pictured.
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10587.jpg)
Autometer Ulra Lite 2 1/16" Nitrous Pressure mechanical gauge - $30
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10586.jpg)
Nitrous Express Bottle Heater wrap - $55
All I have is the blanket heater, great replacement for someone with everything else.
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10577.jpg)
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10576.jpg)
Zex Nitrous Bottle brackets, stainless with rubber bracket covers NEW- $12
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10575.jpg)
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10574.jpg)
Brand New Ls1 F-Body Starter - $70
This is designed for your Chevy LS1 engine. This motor turns your engine over faster than any stock starter. It produces 30% - 40% more cranking power than a stock starter. This starter also features an offset design which allows more clearance between your oil pan and starter.
![](http://i143.photobucket.com/albums/r136/joekeating1/SDC10573.jpg)
